Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
How do you remove and replace the water filter for Conquest side by side
I am trouble removing the while filter. It seems to be very tight and I don't want to pull to hard on it for fear of breaking it and causing a leak. There are no instructions with the unit that came with the house.
  • 958 Answers
Where is the water filter located?..
if it is inside the refrigerator top shelf, then just twist it countr clock wise and it would fall down right away.
if it is at the bottom front freezer side, turn it also counter clock wise and pull it to the front. it is just being hold on to by an o-ring at the tip of the filter.
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
GE Fridge - The water filter bypass plug is stuck
Should just take a quarter turn CCW to remove. You may loose a few drips of water, but the water shuts off automatically when the plug or a filter is removed. A wrench should not be needed to do this.
Jul 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Light burnt out
The bulb screws in a little tight , to help keep moisture from the socket . Cover with a cloth when removing .
Jan 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
My Whirlpool side y side refrigerator purchased last year august is not dispensin water but making ice. I have replaced the filter but still not dispensing water.
there iis a switch on the door dispenser that operates when you slip your glas up for cold water and in doing this you should hear a click from the solinoid when this part of operation takes place
if no noise then probable the solinoid is faulty
if there is a noise then disconnect pipe going up inside of door which in toe kick area try pushinhing on switch to operate if no water comes out remove filter and try again, water should come out where the filter is situated
if no go replace water valve
Nov 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water line hooked up makes ice but no water from dispenser
Have a look at the back of the fridge. There are 2 valves that feed the ice maker and the water dispenser. Have someone push the dispenser button while you feel which solonoid activates.Once located,remove that single pipe from that valve and reactivate the dispencer button. If water shoots out then you know the problem is further on. I would suspect there is then an issue with the water filter. Remove it and inspect for defects. If the filter is old, suggest you replace it as they clog up reasonably quickly. Retry. Please let me know.
Oct 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water Filter
most whirlpools have the filter located in the bottom kickplate, right below the freezer door. turn counter-clockwise and toward you to remove. if it has never been removed before, they are hard to get out the first time.
Jul 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Can I remove refrigerator filter if hooked up to RO system?
its not necessary to keep the filter in place with an r/o system.
Thanks for using FixYa peyton
Feb 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Removing the water filter and not replacing
Not with out re plumbing the unit underneath, it would be much easier to leave it in place.
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water line to the water dispenser has rotted; best way to replace
take and get a coulpling at the hardware stoe that is real tight inside of the tubing and then you can either gently pull the new line into the door after removeing the inside of the refrigerator and getting to the access to the back side of the ice and water controls and replace the tunbing. have a quick connect for the coupling at the bottowm of the freever door so that all you have to do is uncoiuple it and remove the door. Be careful not to pinch the tubing when you remove the door ever. Good Luck and you can ask me more questipons here at FixYa. Please don't forget to rate this solution fo hte answer please. Happy Neew Year!!!
Dec 21, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Refrigerator
Ok you have to pull the collar back at the sametime and remove the line.To be sure send me a picture to archieferrarini@yahoo.com
May 18, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
96 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
