Question about Whirlpool SF367 Gas Kitchen Range
Whirlpool cooktop,built in oven and range
After the power failure, PF is shown on the diplay. I tried to reset by pressing off/cancel to clear "PF", and even the "start" key but nothing works. It looks like all control functions have been locked up. Any suggestions?
Not be funny, but I have the same problem-and/maufacturer
Wirlpool makes a pice of junk! and my range (3 years old) is going in the trash soon.
This range uses a computer and it has NO fan to cool the computqer look at you computer it has a fan.
Posted on Mar 03, 2009
I have a 30" electric freestanding range
The stove is working but the oven is not. Also the clock is not.
Our house was hit by lightening. Please help. Xmas dinner is only 5 days away.
Posted on Dec 20, 2008
My whirlpool oven of 4 years, will not turn off. the tech say it is the broil relay switch, is stuck
Posted on Oct 08, 2008
  • 409 Answers
Sounds like the clock is defective. ovens don't have a built in UPS, like computers, so when the power goes out, it usually takes the clock with it.
have a technician replace it.
Posted on Sep 13, 2008
What's wrong when the oven panel shows PF and doesn't work anylonger
PF stands for Power Failure. Just press the STOP or CANCEL key. That should clear the PF message, and allow you to enter in the clock time and operate your oven.
Oct 09, 2014 | Kenmore Kitchen Ranges
Kitchaid electric range display PF what to do
PF indicates a Power Failure. Turn off the power supply (for 30 seconds or more) to the unit and then back on, select/touch the range cancel/clear pad and reset the clock. The range should work again, unless there was damage to the control during the power interruption.
Oct 05, 2014 | KitchenAid KERS807SSS - Freestanding...
Red light on stove surface is lite up red and code pf is on display
"PF" displayed on the control:
A temporary power failure has been detected. Press the Stop/Clear keypad to reset your control. You may need to reset your clock.
Apr 04, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
What do you do when PF is one the screen
PF Power failure PF flashes to indicate that a power failure occurred while the dryer was running. Press Start to continue the cycle, or press Pause/Cancel to clear the display.
Nov 25, 2010 | Whirlpool Ovens
Whirlpool duet gas dryer PF error will not reset as per manuals
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
PF Code on Duet Electric Dryer
just press cancel means power failure ..if still not clearing probably control
Aug 15, 2008 | Whirlpool GEW9200L Electric Dryer
Had a power failure and now getting a PF E1 error on the control panel
F5 - E1 and E2 Check door/latch switch Replace switch if defective
It has detected a problem with the switch on the door lock motor. In most cases the switch will need to be replaced.
Nov 22, 2007 | Whirlpool GBD307PRS Stainless Steel...
PF means power failure.  Usually you can hit cancel or clear and this will go away.  Let me know if this helps.
Oct 12, 2007 | Whirlpool RF378 Electric Kitchen Range
Kitchenaid electric range
This one can be a little tricky. I really need to know a lot more information to give you a good answer. You are right pf does mean power failure. This is detected by your power board the is located under the cooktop. If you select cancel the pf should disapear and you should be able to use your oven. You didn't mention whether the control board displayed the pf before you actually tried the oven. If it did, and it gives you that error every time you use the cooktop for a period of time, you could have a problem with the thermister located right behind the console. To remove the console just remove the screws on the under side then lift the console straight up and off.
Jun 15, 2007 | KitchenAid KESI901P Electric Kitchen Range
Whirlpool SF367 Gas Kitchen Range Logo
373 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
