Question about Hotpoint Aquarius WMA56 Front Load Washer
Keeps fusing Washing machine keeps shorting the fuse. T he correct fuse is being used (13amp)and has now been replaced several times, different plug sockets where then tried and the machine worked for two months until the fuse went again. Changed fuse again and tried in a completly different socket. It went half way through a normal 40degree cycle then fused again. When it does stop working it makes a loud klonking noise that sounds like someone has thumped the side of the machine.
  • 641 Answers
It seems like something is prevent tub's free movment. Try to spin the clothes tub by hand and look for a free movment. In case it doesn't move smoothly,maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent its clear spin. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port. Be aware you should disconnected the power cable before starting your tests !! Good luck !!!
Posted on May 23, 2006
Siemens wxd 1260
First things first
this may sound condescending but we need to rule out the minor thing first,
ensure that there is power going to that socket by testing it with a different electrical item ...radio or whatever.
if that's ok
ok change the fuse in the washing machine plug...ensure you replace like for like in terms of the fuse will normally be 13amp but read what the fuse says.
failing that you will need to get a certified person out as I would not recommend anybody to touch the electrics were water I concerned.
Hope it's an easy fix for you, if not it may be just a loose wire to the main board in the machine of it could be more sinister like a fried board :-(
good luck hope its an easy nd quick fix
Apr 15, 2014 | Washing Machines
My washing machine kkeps tripping my fuse box
This is related to a fault in the main control panel, it is possible there is a short if the fuse keeps tripping off. You need to remove plug and pull out the panel to check for short in the power supply to the main control panel usually a SMPS unit. Use a multimeter to check for short, if so this must be replaced.
check for tips from the link below:
http://www.espares.co.uk/advice/washing-machines/a/7/1298/how-to-replace-washing-machine-controls-hotpo.html
Apr 30, 2012 | Hoover Nextra HNF 3157 Front Load Washer
My washing machine is blowing my fuse!!
either the motor start capacitor on the machines motor is shorted,the motor winding itself is grounding itself out to the case and shorting or you may have a bare wire touching the metallic frame in the machine
May 14, 2010 | Washing Machines
Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
May 20, 2009 | Maytag SAV571EEWW Washer
Blown fuses
please check your fuse box, it must have 22amps fuse. if not than upgrade it.
if your fuse is of 22amps or above, than my friend you have to replace your switch...............thank you and have a nice day
May 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Sanyo EMS1000 microwave. Keeps blowing 13amp plug fuse.
New or older wiring to microwave? Is there a GFI circuit installed?
Apr 27, 2009 | Maytag MMC5000 Microwave Oven
Need washing machine fixed
engineer rquired i'd say. most times will be the heating element shorting. but dangerous to keep changing the fuse. the fuse is a symptom not the problem.
Jan 27, 2009 | Indesit W 123 Front Load Washer
Indesit washing machine wdg1295w blowing fuse
Proberly carbon brushes in motor,Can be supplied if req.grandadfixer
Oct 11, 2008 | Indesit W 123 Front Load Washer
Washing machine
the problem you are have there is if the machine is bolwing a fuse becauce the heater element is falty replace the heater and all shall be fine again noffie....
Apr 05, 2008 | Indesit W 123 Front Load Washer
Washing machine blown fuses
Hi - had a similar problem with about 3 different makes of washing machine - the RCD switch on the main household fuse box was continually tripping . Nobody could give me a right answer . Eventually ended up with a Hotpoint . Felt sorry for the delivery guys from the electrical retailers having to keep dragging machines in and out .
May 07, 2007 | Indesit WA 115 Front Load Washer
Hotpoint Aquarius WMA56 Front Load Washer Logo
141 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
