Question about Roper RS25AEXLQ Side by Side Refrigerator
Water in ice cubes
The ice cubes are not frozen all the way and that leads the excess water to dump in the bin causing the other ice to hang up in the shaft and not dispense properly.What could be wrong?
  • 4,070 Answers
Hollow ice is usually caused by low water pressure. There is a mesh strainer in the water inlet valve where the water supply is connected. Make sure it's clean and that you have enough pressure. The pressure at the water dispenser may give you an indication of the pressure.
Posted on Aug 14, 2009
My ice maker inst working Whirlpoo; model gz25fsrxyy2
By "ice maker isn't working" do you mean it isn't filling with water, it isn't freezing the water in the ice maker, it isn't dumping the ice cubes into the bin, or it isn't dispensing ice cubes?
Was it previously working and it is not working now?
Typically one can hear the valve when it opens to fill the ice maker with water. Can you hear it attempting to do so? If so, and there isn't any water in the ice tray, check that there is water supplied to the valve at the wall and the valve is open. Is there a water filter? Has it been replaced per the manufacturer's recommendation? (Typically, the water filter should be replaced every six months.)
Is the "full" bar pushed up? It shouldn't be. The bar above the ice cubes should not be in the horizontal position. That position tells the ice maker the bin is full so it should wait until the bar goes down, indicating some ice has been used.
Can you hear the bayonet turning? Is the ice maker attempting to dump out cubes whether or not they exist? The next issue after you confirm there is water going into the ice maker that is being frozen and the ice maker knows to dump the ice, is the bayonet. There is a motor that turns the bayonet and a mechanical connection. Either could be at fault.
Jan 22, 2018 | Refrigerators
Water collecting in the water compartment
what is question as well as make ,model of unit
Nov 13, 2016 | Refrigerators
Manitowok ID0452A-161 water not draining one water tray is filled causing water to over flow into ice bin melting ice. Need to know where the float switch is and dump valve solenoid. FOR TROUBLESHOOTING
Remove side panel on left. Dump valve and drain hose usually blocked with silt, but may be dump valve coil open circuit. No float switch, water level sensor above tray.
Mar 04, 2014 | Manitowoc ID0452A-161 Dice Cube Air Cooled...
Ice is dumped before totally frozen.
Sounds like a water valve problem. The hollow ice cubes are the giveaway. This means not enough water. only things it can be is the ice maker is not turning on the water valve long enough or the water valve is restricted or the water valve has been leaking and has frozen the fill tube. and is only leting out a small amount of water in this case as well you will still need a new water valve.
start with water valve and if that does not solve the problem you will need to replace the ice maker.
Jan 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
I have a Whirlpool refrige. side by side and the ice maker has stopped working. The infrared light keeps blinking. I have unplugged it a couple of times as well as turned the infrared off. Any advice?
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sep 05, 2009 | Whirlpool Refrigerators
Frozen slabs of ice instead of ice cubes
the icemaker could be leaking by can you see where the water is coming down into the bin from??
Jan 23, 2008 | GALAXY Microsystems 55622
Roper RS25AEXLQ Side by Side Refrigerator Logo
113 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
