Question about Mitsubishi WS-65809 65" Rear Projection Television
Ws65809 tv ne one there
  • TRAVLINMAN80 Sep 16, 2008
    WHAT DO U MEAN BY FLUID????????????????????????????????BIG IRISH??
  • 927 Answers
Good Day, TRAVLINMAN80;
Sorry for the late response but have been dealing with IKE down here in TX. I think the problem your TV is Fluid. Good Luck, big IRISH.
Posted on Sep 16, 2008
  • MICHAEL MULLINS Sep 16, 2008
    Good Day,
    The rear projection TV uses three CRT's and kept cool by using 'coolant'. The "coolant are in chambers and they have history of leaking. When they leak the fluid drips on the PWB's and cause unusual concerns. big IRISH.
I have a Mitsubishi WS-55809 projection TV. The convergence will not ajust using the user controls and the picture looks bowl shaped in every format.
you will need to install a convergence repair kit for your model. You can get the repair kit called the " WT46807, WS55807, WS65857,WS65907, WS73907 WT46809, WS55809, WS55819, WS65809 and WS65819 Convergence repair kit " which has the parts and the CD with instrucions. Its available at the following link http://tvrepairworld.com/mitsubishi_repair_kits
Feb 07, 2013 | Panasonic PT-56WXF95 56" Rear Projection...
Yes i have a mitsubishi big screen tv model ws65809 made in 2001 the guns need to be ajusted can you tell me how to ajust them
dear,
what kind of problem u r facing so that u thought the guns adjustments
regards,
dont rate it untill satisfied or solved
Aug 23, 2008 | Televison & Video
Location view of 2.5 chem fuses
Fuses in the ws65809 are identified by a location number printed top and bottom on the board---need a link for the full service manual for this TV?
What exactly is problem and such.
Apr 29, 2012 | Mitsubishi WS-65809 65" Rear Projection...
I have a mitsubishi model ws65809 big screen tv. When I turn power on it only stays on for 10 seconds then shuts off. I checked the fuse but fuse was fine.I want to know if I changed the lamp will it fix...
You will need to press the menu button and the input buttons on the TV both in together for five secoinds then count the two digit blink code from the power indicator. the blink sequence will repeat several times. let me know the sequence of the blinks.
May 30, 2011 | Mitsubishi WS-65809 65" Rear Projection...
MITSIBUSHI WS65809 TV
Good Day, GLENN;
I assume that IHVT was arcing from the side, and the audio is from the TV and not stereo? Or was it the high voltage splitter? Was it plug in or soldered IN? It sounds like you may have bridged a solder joint, unplugged something by accident or something else? Double check your work first of all. Do you still get high voltage? You may poor part. Good Luck, big IRISH.
Sep 13, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Yes my nickname is cztop i have a mitsubishi big screen tv & need guns ajusted
try unplugging tv for 30 minutes remove all speaker away from tv and anything magnetic after 30 mins turn back on try that
Aug 23, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Ws65809 projection tv
You can purchase parts online at these two links
http://electronix.com/ or http://www.matelectronics.com/
Either one should be able to help you out. If they dont stock your part check back with me and let me know exactly what your looking for and i will post a link for you. Hope this helps.
Jan 05, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
