Question about Daewoo DTQ-25S3FC 25" TV
Broken power button
I broke the power "on" button on this tv. Is it a fairly simple repair? How do I get to it? is there a manual that tells me how to get the tv apart so I can replace the power button? Thanks, irish
  • shytownb Jul 03, 2008
    I have an Orion.The power button does not work.We were using a universal remote.However,the children took the batteries out and you have to have the tv power on to reprogram the remote.Can the power button on the Orion be fixed?Is there a remote that can be programmed withn the tv off? Thanks
    President:
  • 3,130 Answers
Unfortantly the power button on the front panel in most cases are part of the entire front part of the cabinet! In some cases you can take off the back and gently pull and slide out the chassis then you can see if it just slipped down below the switch or is it broken?? The front cabinet for this set is expensive and you probably would not want to replace it but you should be able still to use the remote control. If you dont have the remote a universal should work or you can most likely get an original replacement remote from 1-800-remotes or at http://www.remotes.com Good Luck
Posted on May 23, 2006
Repair beeman rs2 broken spring
My stupis Beeman RS2 dual-caliber Air rifle combo trigger broke for no reason and I cant find a replacement can someone help me?
May 29, 2012 | Beeman RS2 Dual-Caliber Air Rifle Combo...
Back door wont open
Most common reason is a clip inside the door that connects the handle to the latches is broke. With the help of a Haynes manual from the local auto store. It is fairly simple to take off the door panel and see exactly which part is broken. I hope this helps please rate this thank you
Mar 03, 2010 | 2004 Lexus GX 470
Need Location of Part # on right front circuit board (if looking at it from the back of the tv) I just finished soldering in new IC heat-sinks on this board and set on top of TV and a cat jumped on it...
I think you will find the board for this set is not available or if it is not at a reasonable price.
Usually if a fairly small part of the board is broken off it can be repaired-----I can tell you what is involved in this type of repair if you give me some idea of how bad the damage is.
I have repaired circuit boards broken in half---once fixed they are not pretty but will work perfectly.
let me know if I can help you--I am here to help.
SD TECH
Oct 09, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Test
Ballast Lamp provide back light in DLP TV and if its bad / broken TV wont power up. If lamp is weak, dark or less bright picture will come in screen. Color wheel is responsible for colors in picture and if its broke, TV wont power up and common problem with color wheel is high pitch noise while it spins.
Jun 12, 2009 | Sharp 65DR650 65" Rear Projection...
How can I get pictures off a broken phone??
OK, if the inner PCB is intact (or repairable) it is a simple swap to good body, screen and battery, crack the old users PW/PIN etc and you are in ;-)
Not hard, just timeconsuming
Find a replacement at Goodwill shop, swap shop, pawn shop, Craigslist etc (gotta have good screen and button area) and ring me up. In the meantime I'll gather the tools you'll need to DIY ok?
Mar 26, 2009 | Samsung SGH-e315
Presario X1000 broken power button
http://www.squadrainformatica.com/?q=node/1258
Sep 17, 2008 | Compaq Presario X1000 Notebook
Red bowed lines
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Aug 06, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony 65 inch kp65wv600 images look bowed
  • Screen looks 3D
Jun 21, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Proscan PS50700 Convergence Problem
  • Screen looks 3D
Nov 09, 2007 | Proscan PS50700 50" Rear Projection...
Daewoo DTQ-25S3FC 25" TV Logo
355 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
