Question about Toshiba 2060 Copier
How to change developer on Toshiba 2060 copier?
I have a Toshiba 2060 copier and the copies come out gray. It was previously suggested that I clean the optics and change the developer. Does anyone have step-by-step instructions for the change of developer procedure? Or know where a link is for me to download them?
  • Anonymous Mar 21, 2014
    steps for high darde in service mode, the developer in Ricoth FT3813
  • Toshiba Master
  • 2,794 Answers
Changing the developer is a procedure for service technicians to do.  You might want to ask that question on copytechnet.com.  There are Toshiba service technicians on that can help you with that.
Posted on Sep 13, 2008
My toshiba 2060 copier easy printing but print paper some line missing please or broken,please solved my prob.
if white lines appear in your toshiba 2060 inaccuracies.
almbres replace the corona charging and transfer, do not forget to check the development unit if turevelador is too old replace
Feb 25, 2015 | Toshiba 2060 Copier
Black shade in copy
Hello
You didnt give much information, so please start with cleaning all the mirrors of the machine.
If after that you still have the same problem replace the developer material.
Regards
Jul 22, 2011 | Toshiba 2060 Copier
Copy comes out very dark with wavy bands
try to clean the mirrors inside
if still dark and it makes over 50000 paper you need to change the drum & developer & blade
Jun 16, 2011 | Toshiba 2060 Copier
I have a Toshiba 2060. Runs great except for one issue. The cartridge has the paper oriented landscape with the label LTR. When I copy using the eith the ADF or platen glass and the paper is also...
As far as I know the Toshiba 2060 does not have an auto rotate function. This means that whatever drawer you pick to copy from is what the scanner will scan. To change which way you copy your sheets you will have to change the physical size of the drawer to copy the other way.
Aug 31, 2010 | Toshiba 2060 Copier
Have toshiba 2060 copies are coming out with gray and blk stripe
Hello sir; Everything you can clean but drum, that's most sensity part, UNTOUCHABLE , I believed you damaged the drum already, go change one meanwhile change cleaning blade too.
Mar 09, 2009 | Toshiba 2060 Copier
Toshiba 2060 copier. What happens when developer needs changing?
Hello sir; the developer on this model is requested every 80,000 copys need to change, if don't change the image will be fade.
Jan 05, 2009 | Toshiba Estudio 200L Copier
When I copy the paper gets out white
The drum unit may not be in correctly. There is a good chance its not up against the developer station like it should be.
-jen
Oct 29, 2008 | Toshiba 2060 Copier
Copies too dark
1-drum needs changing
2-wires needs changing (the cleaning doesn't do anything for it)
3-developper needs changing.
Sep 23, 2008 | Toshiba 2060 Copier
Copies have gray background.
Have you had the optics cleaned resently? If not Iwould start with that and make sure you have the copier unpluged and don't forget to clean the two mirrors under the Black Box/cover. It could also,mean that you need a new OPC drum and blade.. It depends on how maiy copies are on the copier and drum...
Sep 04, 2008 | Toshiba 2060 Copier
Change developer on a toshiba 2060
For that pls contact a trained service engg
You may contact to HCL infosystems Ltd
Address
HCl Infosystems Ltd
261, Okhla Ph-3
New Delhi-20
Ph : 011-26328528-31
Fax : 011-26328532
Jul 09, 2008 | Toshiba 2060 Copier
380 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
