It is important to confirm if the amplification fault is with the amplifier or it is with a weak signal. So it is important to check your source with another amplifier or if you are using FM and still experience the fault then check if the ATTENUATION switch is activated which can reduce the main volume. Also check the speaker individually with a AA battery to get a good response.
If so there is fault in the pre- amp section Please test the other inputs available on the amplifier. Also if you are using the preamp out check the cords or the Input signal must be applied to all the source to confirm. This can also be a failure of the A/D input selector.
Take consensus as there are high density boards and will require help with jig to check the boards.
