Question about Fuji FinePix A330 Digital Camera
HELP ME To whom I am speaking to I have a fujifilm finepix A330 and the zoom button is broken. It will zoom in but not back out I had put in on night mode to take a picture and know it's suck and all my pictures a blurry. If you can help me that would be great
You might try whacking it a few times against your hand as you open and close the lens cover. Mine was stuck in completely and showed a zoom error. This solved the problem.
Posted on Jul 26, 2007
  • 116 Answers
Hello, there is an electrical contact area on each side of the zoom button, one for in, and one for out. The contact area for the out side of the zoom is either dirty, or broken. First, you might want to spray just a little of some contact cleaner (you can get it at any radio shack or hardware store) around the button over the zoom out contact. Then push the button (without the power on) about 20 or 30 times. Power up and see if it works. Please let me know. Best regards, nightdiver
Posted on May 23, 2006
0 characters
3 Points
Is the firmware for fuji finepix A607 the same
Heres the support site for that camera - theres no firmware listed I would not use the A330 firmware although considered identical - Its NOT it is identical to the A330, except for the fact that it uses a Super CCD sensor instead of the standard / conventional sensor in the A330...
why do you want to update the firmware ?
Apr 10, 2010 | Fuji FinePix A340 Digital Camera
Help with my my fuji finepix a330
If your new card has the letter "H" or "M" on it, your A330 isn't compatible with it unless a "firmware" upgrade is performed on the camera. Here's a link to the process, which you can do by following the steps.
If solves your problem, please rate the help favorably. Thanks
Nov 25, 2009 | Fuji FinePix A330 Digital Camera
Lcd screen stuck in usb mode?
Try removing batteries and card and leaving them out for a while to allow camera settings to default.
Replace batteries only and see if you get "Card Error" message.
If you get this, then try again with card fitted
Check firmware version
Possibly card storage too big. Upgrade firmware to version 1.77
If you have no user manual there is a PDF version available to download here:
All the error messages are given in the manual with possible solutions.
Aug 25, 2008 | Fuji FinePix A330 Digital Camera
Card not initialized
Try removing card and cleaning contacts with a soft dry cloth.
Reformat and try again.
PDF manual can be downloaded if you do not have printed copy
Error messages and possible solutions to try are given in the manual
Aug 21, 2008 | Fuji FinePix A330 Digital Camera
Inmtiialized means Format-
If you cann do this check the manual for more detail
Jul 07, 2008 | Fuji FinePix A330 Digital Camera
Need manual
Try this:
Dec 03, 2007 | Fuji FinePix A330 Digital Camera
HELP! Zoom Error?
Common fix is to remove batteries hold the power on button down for five seconds and then try it.
I take it the lens isnt off true / loks straight?
Nov 13, 2007 | Fuji FinePix A330 Digital Camera
In order to use Type "M" xD cards, you need to upgrade the camera's firmware.
Read here:
Oct 21, 2007 | Fuji FinePix A330 Digital Camera
Zoom button broke on finepix A330 camera
The best thing you can do is get to the nearest service centre.To find one in your location click on the link, scroll down to the end of the page and choose your region, Country/area, And topic from the dropdown menu and you will get the contact info of the nearest service center.
Oct 08, 2007 | Fuji FinePix A330 Digital Camera
Memory card problems...Fuji FinePix A330
Same thing happened to me.  I ran across a website that allowed me to download a free recovery program that looks at memory cards.  Thankfully this free program allowed me to recover all 232 pictures I had saved from a trip to Spain.
Here is the link I used.
Oct 03, 2007 | Fuji FinePix 2800 Zoom Digital Camera
Fuji FinePix A330 Digital Camera Logo
152 people viewed this question
Top Fuji Digital Cameras Experts
Richard Roberts
Are you a Fuji Digital Camera Expert? Answer questions, earn points and help others
