Question about Whirlpool Duet GHW9150P Front Load Washer
Controls Locked - How to Unlock?
All of a sudden the controls on our washer are locked, and we can't figure out how to unlock them? Does anyone know how to unlock this feature? Nothing will work with it locked.
  • 1 more comment
  • ilove2teach3 Sep 14, 2008
    It is flashing F02 and the water will not drain out. The door won't open.
  • keveolsen Jan 23, 2009
    I have found the 3 hex screws under the 'kick panel' by feeling at the base of it along the floor (ours is on the floor, no riser). Was able to remove the screws. How does one 'remove' the panel? I don't want to break anything
  • derekferr Jan 25, 2009
    Hi, my control lock light is on. I emptied the trap basket behind front panel still don't work ???
Hi Sears Tech Too!
I don't see any hex screws pn the kick panel. The only ones I see are on the inside of the door. I see now that the Model is a Duet GHW9150PWO. Can you help????
Posted on Sep 14, 2008
    Sorry, I didn't mean to give you a sad face! After all, you are the Guru. I have never used this site before. My fault! You deserve a happy face for trying to help me!! :-)
    Novelist:
    Champion:
  • 261 Answers
These are seperate problems, F 02 on whirlpool is a drain issue, this is were you need to remove the three hex screws on the kick panel below the door and using a bucket remove the cleanout on the pump and drain what water comes out and remove the filter and check the pump for damage. The other problem is a duel feature button that needs to be held for 3 seconds to unlock, I am fuzzy on the location, look carefully for the writing blends in with the panel.
  • John Robbins
    John Robbins Sep 26, 2008
    I mess with so many front loaders I forget too. Yeh this one is more fun, I would pull the back off and do it that way so you dont experience the door boot spring!
Washer kenmore elite washer model 417.41102000 displays LOC and won't turn on. how to reset and unlock the controls?
Control Lock (Press & Hold) To lock the controls between or during cycles, press and hold the Add Steam button for 5 seconds. ' will be displayed if you attempt to wake up a "between cycle" locked unit and ' will alternate with cycle time remaining in a "during cycle" locked unit. Repeat to unlock the controls when you are ready to operate the washer. Use this feature to reduce the likelihood of accidental operation by children. 41741102000 KENMORE ELITE WASHER Manual Sears PartsDirect
Hope this helps?
Mar 29, 2016 | Kenmore Washing Machines
Controls locked
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Aug 06, 2012 | Whirlpool AWM9000 Front Load Washer
Control Locked light on
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the DRAIN/SPIN button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Kenmore Elite 45986 Front Load Washer
Control locked how do I unlock?
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds to 10 seconds.
Please do refer this link for a detailed explanation for your knowledge.
http://www.fixya.com/support/t4186517-control_lock_light_machine
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My control is locked. How do I unlock the controls?
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, or by leaning against the control panel and is usually not an indication of a washer malfunction.
If this is a Whirlpool Duet series FRONT LOADER, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please post back and let me know. I hope this corrects the problem for you.
Mar 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our washer says control locked. i dont know how to
Unplug the washer, and leave unplugged for about 5-minutes. Re-plug and check. Hopefully this resets the controls.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I was doing a load of laundry and the washer "froze" i tried to cancel the load but it wont stop.... i ended up unpluging it and even when i plugged it back in its still stuck!!!
Locking controls
lit, all buttons are disabled. You can lock the washer while it is
operating.
Select and hold END OF CYCLE SIGNAL for 3 seconds.
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer controls are locked.
http://www.managemyhome.com/mmh/owner_manuals/search?query=kenmore+elite+45986&s=HomePage
It looks like there are 3 different variations to this model. Hope this helps. If you click on Launch Now, it will take you to a question and answer forum.
Aug 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 CONTROLS LOCKED
Apparently there is a child lock on the machine and by holding down the spin and drain button for 3 to 5 sec. this will unlock the controls
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
123 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
