Question about Whirlpool Duet GHW9150P Front Load Washer
Control panel Everything worked fine then one morning the control panel was locked. How do you unlock it?
  • Anonymous Sep 13, 2008
    the control locked button was lit when we got home from a week away and we can't seem to undo it. I tried unplugging the machine for a while, but the control locked button remains on.
You have accidently activated the control lock. Press and Hold End Of Cycle signal for 3 seconds and it will unlock
Posted on Sep 14, 2008
Mervia. Why is central locking not locking any door?
It's only an educated guess. If all other locks switches are working it' either the switch panel itself or an electrical short. Switches are popular, get it checked first
Nov 22, 2015 | Vauxhall Cars & Trucks
I have a '98 Ford F 150 and the power door locks will lock but will not unlock. Do you have a wiring diagram that will help me troubleshoot the problem or is this a common problem with Ford that someone...
ck if either pass or driver switches will work. the lock actuators are common to be bad, but, if they lock but wont unlock more likely a switch problem.
Sep 16, 2009 | 1998 Ford F150 Regular Cab
2006 bmw 325i remote only unlocks driverside door. will not unlock all doors when you lock it from the inside. have to use key in remote to open door. also central button to unlock doors is inop
fuse 56 and 57 control central locking,the issue is caused by surges typically in the front door lock actuators, normally at a dealer they would replace fuse 56 and 57 with a 20a mini fuse and if still occuring repl the door lock(s) that dont work or typically both front, first replace fuse 56 and 57 with 20a fuses as were too small from factory and than operate ten to 15 times, if it doesnt work at first dont panic,let the car go to sleep which takes about 16 min and than try again this problem has nothing to do with the key fob or the lock unlock button inside,also the fuses are located behind the glove box just rere the access panel and they are found at lower left section
Jul 23, 2009 | 2006 BMW 3 Series
Control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
May 25, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
2001 Civic SI (EX american) remote lock problem
OK - the master switch is the switch panel on the drivers door that controls every lock and window of the car.
If you are pressing LOCK and all the doors LOCK except the driver's door - the Locking Actuator's Solonoid has failed.
You cannot replace just the solenoid - the entire thing is replaced as a unit.
It looks similar to THIS....
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 14, 2009 | 2001 Honda Civic
Drivers door power lock wont work.
Either the wring going to that motor or the motor itself is bad.
Mar 08, 2009 | 2000 Toyota 4Runner
Control lock
bottom button on last row on right side of control panel depress and hold for 3 seconds it should activate or deactivate control lock if this does not help you could have a faulty control panel
Dec 14, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
19 people viewed this question
Dan Webster
Dan Webster
Sal De
