Question about Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta Z5
Hopefully you'll be able to guide me in the right direction because my camera is been a complete nightmare at the moment. The camera powers on and i can view all the previously saved photos but when i try to take a photo there is nothing coming up on the lcd or through the viewfinder. The lens does extend out so there is no problem with the lens. Does this mean my camera is wrecked?? It was wrapped up in my rucksack when travelling but was working fine when i returned. This was a pretty expensive buy for me and i really really need your help. Thanks for any advice you can give me
    Novelist:
  • 107 Answers
This sounds like a jammed shutter. There is a very delicate assembly inside your lens which blocks light from the image sensor at the moment you snap the picture in order for it to be able to record what it was seeing at that very moment. Normally after the sensor has finished recording the image the shutter will re-open allowing you to compose another image. If you see the icons and text as you would expect, but do not see any image - this shutter jam is the most likely cause. This assembly is so delicate that even slight impacts, condensation, or contamination from dust or dirt can cause the shutter to not open after it has shut resulting in a black image at all times. The shutter will sometimes clear itself and begin functioning again, but usually it requires disassembly and manual re-setting. Due to the complexity of the lens assembly in this camera (because of the anti-shake features) you will need to send the camera to the manufacturer if you wish to get this problem fixed. David Millier Advance Camera Repair
Posted on Feb 27, 2007
I can't get rid of Error message on my Konica Minolta Z5 : SD card seems blocked, even after reformatting, because some pix may have been rotated 90 degrees ???
The Z5 can display photos that it took. However, it cannot display edited photos. Due to the way the JPEG standard is defined, a rotation of the picture constitutes editing. If you rotate it four times, or once and then undo, it still constitutes editing. If you open a picture and then save it without doing anything else, it still counts as editing. Thus, if you want to put pictures back onto the card, you'll have to use the original pictures.
The proper workflow is to download the pictures to your computer. Then, if you're going to do any work on any of these pictures, do it on copies. This way, if you totally mess up an edit, you'll still have the original.
Feb 01, 2012 | Konica Minolta DiMAGE Z5 Digital Camera
Tip
I have almost identical issue with a Dimage Z5 (Konica/Minolta). I have had the...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Dec 01, 2007 | Samsung Digimax D53 Digital Camera
My son's camera was dropped in water
If it was salt water, then the camera is irreparable. Fresh water - let it completely dry for a few days before turning it on. Open all compartments to allow the inside to dry. Use desiccant pouches - like the ones they put in beef jerky packages, to sit in the camera.
Jan 22, 2011 | Konica Minolta DiMAGE Z5 Digital Camera
My Konica Minolta Dimage z5 won't play back photos. I get "system error' and the camera shuts off when I try & review photos
After calling Sony and doing all the things they said to do, that I had already done, they then said to send it in for repair to the tune of a minimum 175.00. So I had this brainstorm. I put the memory card back into my computer and formatted it from the computer. It worked for me, so try it, maybe it wil work for you.
Apr 13, 2010 | Konica Minolta DiMAGE Z5 Digital Camera
What size memory card are you using? I have had this problem trying to use a a 4gb card, which apparently is not compatible with the Z5. Using a 2gb card seems to alleviate the problem.
Jan 03, 2009 | Konica Minolta DiMAGE Z5 Digital Camera
Dimage z5
I have formatted the sd card and now I can se the picthures
Apr 04, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
ANTI-SHAKE TURNED OFF
  • Switch camera on
  • Select Menu Button
  • Menu item 1
  • Use controller to move down to anti-shake
  • Use controller to move right
  • select i) Disp + Exp ii) Exp only iii) Of
Go to http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-z/dimage_z5/Z5_OM_E_.pdf for a Z5 manual
Jan 26, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Using as an internet camera
you cannot connect it directly to computer and use as a web-cam. the only solution i can think of is connecting through a video adapter.
Feb 22, 2006 | Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta DiMAGE Z5 Digital Camera Logo
404 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
