Question about Brother MFC-665CW All-In-One InkJet Printer
Error messages and print problem
HI,
My MFC-665CW is displaying a code "unable to clean 50" and when I try to copy or print I get "printer busy"
  • 286 Answers
There are a couple of things that can cause this fault.
The most common cause is a paper jam has occurred, and the user hasn't gotten all of the paper out.
Lift the lid, use a light to look into the left side of the head travel area. Make sure there is no crumpled paper. If not, carefully move the head all the way to the left and try to look at the right end of the head travel. Look for crumpled paper again.
If you cannot find any paper, the encoder strip may have become dislodged. You will have to take the machine apart. Open the lid, remove the wid=re civers with a small flat screwdriver. Remove the prop rod (blue piece holding the lid open). Unplug all the cables and unscrew the ground wire. Move the scanner off toward the rear.. Remove the rear cover. Unscrew all screws in the top cover assy. Hinge the control panel outward and remove carefully. inplug any attached cables. Use your scrrewdriver to unlatch the two tabs at the front and pull the upper case assy up and off. Look at the print head. There should be a plastic strip going from left to right that is seated in a sensor on top of the head. Make sure it is seated correctly. Remove any crumpled paper. Reassemble and test.
Posted on Nov 04, 2008
I have a brother's MCF-255MC printer and i keep getting the message unable to clean 50 I followed the steps in the manual and it still didnt work could you please help me?
How do I clear the message "Unable to..." or "... Unable" ? ' Brother
support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod...eu_as...
Aug 18, 2014 - Unable to Clean (Clean Unable); Unable to Init. ... If the encoder gets markings or debris on its surface, it may cause other problems.
Brother Unable to Clean 50 Error - YouTube
? 0:51
https://www.youtube.com/watch?v=8THfCUgYCMU Jun 9, 2015 - Uploaded by Aceh Com
Printer Brother Unable to Clean 50 Error Cara mengindentifikasi Printer Brother Unable to Clean 50 ...
Clear the "Unable to Clean" Message ' Brother MFCJ4510DW ...
? 1:49
https://www.youtube.com/watch?v=EH3CEA3WbEY
Aug 2, 2013 - Uploaded by Brother Office
Yeah, keep it ... Clear the "Unable to Clean" Message ' Brother MFCJ4510DW, ... assistance, please ...
Printer is displaying unable to print/init/clean 50. Have referred
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting Get a Professional Answer ... Have referred to brother manual and there is nothing jammed in the machine. ... To attempt to resolve it, do the following steps created by Brother in this step by step guide to try resolving the error message: ... Unable to init, unable to print, unable to clean, unable 36, error 46, 50 and error 32 are ...
I am getting error:unable to clean 50, was unable to print - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting I am getting error:unable to clean 50, was unable to print - Answered by a ... What is the exact model of your Brother printer? ... For example, MFC-615 ... it is not allowing me to press any thing, I keep getting a beeping noise when I press .... How do I remove error messages, epson wf-2750, PC MS10, I 8/12/2017 8/12/2017.
brother MCF 255MC printer message unable to clean 50 Google Search
Aug 14, 2017 | The Office Equipment & Supplies
I haved an error message on my Brother MFC-665CW--unable to print 51
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Apr 07, 2013 | Brother Multi-Function Center MFC-665CW...
I have a brother mfc-420cn. I am getting a unable to clean messa
Do you mean "unable to clean"?If it this follow this instruction.
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If numberis over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 02, 2009 | Brother MFC 420CN All-In-One InkJet...
How do I clear "Unable to Print 51" Error Code on a Brother MFC-665CW All in one Printer
51 error says that the purge assembly is stuck and not cycling properly. If you can power up and get the printhead to the center and unplug again, look with a flashlight in the far right corner where the printhead parks for any paper scraps or things that don't belong and remove them it might work again. Otherwise a shop repair to possibly replace the cleaning assembly.
Oct 02, 2009 | Brother MFC-665CW All-In-One InkJet...
Unable to print 30 or 50
the encoder strip is probably out of its socket. its a long mylar strip that goes from one side to the other, and goes underneath the printhead.
Jun 25, 2009 | Brother Multi-Function Center MFC-665CW...
MFC-665CW "unable to print" 50 error
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment. You will need to turn off the printer and then push it back into slot to fix it. Let me know if you need more help. Sai.
Jun 11, 2009 | Brother MultiFunction Center MFC-440CN...
I have a brother mfc 665cw printer, had a printer jam, cleared the jam and now recieve unable to print 50 error, unable to copy or print. Have found some information about the encoder strip but I have no...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Brother Multi-Function Center MFC-665CW...
Cleared printer jam, message Unable to print 30
...and 50? Is it toggling between those two error codes?
Anyway, see here what to do:
http://www.fixya.com/support/t211210-brother_mfc845cw
Mar 11, 2008 | Brother Multi-Function Center MFC-240C...
Printer message: Unable to Print
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-665CW All-In-One InkJet Printer Logo
277 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
