Question about Arris SURFboard SB5120 Modem
Modem usb connection
I have a new hp desktop running vista, which connects fine to the net when using the ethernet cable from the modem. I would however prefer to run the ethernet cable to a router, and when I try to use the usb cable connection to the computer it will not connect to the net.Even after running the full installation wizard it says unable to connect...check connections etc. Again it is fine using the ethernet connection.
  • sandlram2 Sep 14, 2008
    Thanks Bubbabear
    That makes sense. Have now run an ethernet cable from the netgear router back to the desktop and all is working fine. Thanks again for your time and info.
  • 2,794 Answers
You can only use the USB connection or the ethernet connection to get it work.  It won't work on both.
What type of router are you using?
Posted on Sep 13, 2008
I have gone to numerous forums and IT friends for support but to no available...nothing at all. My problem I would think not to diffucult but obviously it is. I have a Gateway 560GE running XP. Modem...
When you use USB for networking the "Network" it is on is 10.10.0.1 or similar, Now the Ethernet is 168.192.0.1 or similar. You simply MUST enter the correct address if you wish to change anything. Use the Connect to the Internet wizard and ensure you choose correct net, address. & if you have two Nic's Ethernet & USB, you must make sure you choose right one too.
Feb 07, 2010 | Toshiba Slim Port Replicator II
HP 4450 desktop, not have a ethernet port
No you can't.
But you have ywo other options to use broadband connection.
1. Use a USB modem, or
2. Install a network card to be able to use an ethernet cable.
A network card cost around $10.00.
Don't forget to rate this answer if it helps
Dec 27, 2009 | Computers & Internet
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Inability to connect to Internet
The easiest solution would be to use an ethernet connection. A second problem is probably on most cable modems you can either use a USB connection OR an ethernet connection you cannoot use both at the same time.
Dec 12, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
My laptop has vista installed via usb from virgin cable modem.what must i do to install a belkin wireless g mimo router using ethernet connection?
Huh? You installed Vista through your Virgin Cable Modem? What on earth does that mean?
Are you trying to ask "How do I install my Belkin Wireless G Router?"
If that is the actual question, here is the answer:
1) Unplug your cable modem from your computer.
2) Plug the cable modem into the router using a Ethernet Cable.
3) Plug the router into the computer using another Ethernet Cable.
4) Plug in the power supply for the cable modem and then the router.
(If your cable modem is ONLY USB, and doesn't have a spot to plug in a Ethernet Cable, you'll have to call Virgin and replace the modem with a model that does)
Once everything is up and running, you should be on the internet as soon as the computer starts.
(You may want to log into the router and disable the "Wireless" settings if you aren't using them to stop others from gaining entry to your network)
Oct 23, 2008 | Belkin Computers & Internet
Toshiba Cable Modem PCX1100u
OK. First of all you do not need a special or seperate driver for the Ethernet port. Its factory loaded with your OS.
All you need to do is plug the Ethernet cable into the LAN port on your HP Desktop and then into the LAN port (not the WAN port) of your cable modem.
The second thing is if its only a cable modem, then I suggest you proceed with caution as there is NO built-in firewall on a cable modem. Yes you will get on the net, but you are likely to be attacked with virus the moment you connect. I suggest you check very carefully whether the cable modem (if that's what it is) does/does not have a firewall as you would be very unwise connecting up like that.
Next, forget USB connection to the router/cable modem. That technolgy we've moved on from.. Your Vista shodul be 'plug n play' adn should configure the router for you. obviously that bit isn't so slick on yours.
Let me know how you get on..
Aug 31, 2008 | Toshiba PCX1100U High Speed Cable Modem
Problem connecting DLink modem into laptop
your network adaptor driver is not installed send your mail id i will send the driver for your mail
Mar 27, 2008 | HP Compaq Presario V6000T Notebook
RE: DSL 302G WINDOWS VISTA
Try the following forum - it works!
http://forums.whirlpool.net.au/forum-replies.cfm?t=716454#r2
Jan 28, 2008 | D-Link DSL 302G (DSL-302G) Modem
Trying to get router to work
U can use
USB Ethernet Adapters.Visit:
http://www.ramelectronics.net/network/network-cards/usb-ethernet-adapters/c40000-c43000-c43004-p1.html
Dec 27, 2007 | Computers & Internet
Arris SURFboard SB5120 Modem Logo
201 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
