Question about RCA P52926 52" Rear Projection Television
Rca 52' projection convergence problem
My 6 year old rca 52" just began having a convergence problem. The screen will begin "ghosting" in all 3 colors. When I try to adjust using the remote, it shuts the tv off. when it comes back an its ok 50% of the time. The other 50% its not, and the adjust projection option is gone from the menu. I think it may be some kind of power problem. Any help would be appreciated
    President:
  • 3,130 Answers
Its a good possibility that your convergence problem could for now be cold solder connections on the driver ICs on the convergence board. The longer you use it the more of a problem its going to surge those ICs till they go bad and maybe cause other componet falure as well. If your not a technician i would have this set serviced asap before it becomes a major repair Good Luck
Posted on May 22, 2006
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
Hi I have a 52" RCA big screen tv that is only 3 years old however we turned it on today and it is showing some red blue and green lines and the picture is blurry
Hello clara7,
This denotes a convergence problem. I would suggest that first you enter the menu of your TV ad try to do an auto converge on your set, if this does not work I would suspect that the convergence ICs have gone bad and need to be replaced. I would suggest that you have a qualified TV repair technician replace the convergence ICs in this set.I hope this helps,Shuttle83http://www.electron-age-technologies-llc.com
Jun 08, 2009 | RCA P52939 52" Rear Projection Television
Convergence off line
How did you fix it?????? I though I tried everything!
Feb 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca r52wh74 - no auto convergance
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
Red green and blue lines rca 52' rear proj.
your convergence powert supply is not working-
replace the supply or repair it
Dec 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52'' Projection HDTV Blue ''ghosting''
Go to menu ,now go to setup see if convergence is on menu if not then fuse FL231 is opened 0.6 amps it is located on right side of flyback transfomer the fuse in the middle they look like small square capacitors brown there is 3 in a roll.
Dec 11, 2008 | Televison & Video
RCA 52
ok go into setup menu.... go to convergence.. try to adjust convergence .. does the crosshair move up and down side to side... if not then you might hqve q poblem with convergence power supply if they move then u might have s setup issue
Mar 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52926 52" Rear Projection Television Logo
307 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
