Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Bosch 3.81 cu ft Nexxt 500 Plus bleach not dispensing
How do I get the bleach to dispense on this model. I filled with bleach when washing whites, and when done the bleach is still in the dispenser. Thanks
We had the same problem with the bleach dispenser. It was under warranty so Lowe's sent a repairman that replaced some part in the control panel that he said was faulty on this model. He also said to only use 1-2 Tablespoons of HE detergent and leave the door open. Also dilute any softeners before adding them.
Posted on Oct 12, 2008
Fabric softener does not get dispensed into wash on my Bosch Nexxt 500.
Hi emily446,
Take out your Tray from the drawer (Usually un-clips on the sides or top)
Then clean the holes inside the drawer at the roof. There will be small holes, clean these with either ear-buds or toothpicks. These holes get clogged quite often, and cleaning them will allow water through to the machine again.
Also clean the tray, especially near the hole at the back where the fabric softener gets siphoned through.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Aug 15, 2011 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Fabric dispenser still full after washing completed
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Sep 04, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Some water backs up in the softener dispenser??
Service was here today and tilted the machine backward about 2-4 degrees. This solved the problem. Now fabric dispenser fully empties. Since the machine is 2.5 year old it is possible that over time it settled. I think though it is more likely the cold water dual inlet solenoid that is a bit constricted. If this fix does not last I will change it.
Feb 03, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Adding detergent/softener/bleach
U cud, but not recommended as it cud lead to oversuddsing, causing all sorts of prob's.
Stick to recommended doses.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Fabric softner dispenser
take the soap dispenser drawer out and clean the drawer and the underneath the drawer, then clean the inside of the machine where the drawer fits into to. It could be caused by a build up of soap.
Oct 30, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My Washer STINKS!!!
Wipe out the door (inside the door-pull the rubber back with a javex cloth or something all around the ring). Buy Affresh.........do three loads on the hottest cycle (still wiping all the **** out after each wash) each with an Affresh tablet. If you can't get it......pour a cup of Javex in the bleach dispenser and do as above.
Sep 24, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosh washer won't dispense softener. cleaned the tray and tested it by filling with water and it drained completly out, so i know its not clogged. washed another load and softener still there at end of...
I had the same problem. the only thing that works for me is fulling the fabric softener compartment all the way to the top with water then it will syphon down! it adds it to the load at the start instead on the rinse cycle but its better then nothing!
Jul 28, 2008 | Bosch Washing Machines
Acoustic signal
select a cycle. hold down two option buttonsat same time until you hear ashort signal this disable it. (bleach& rinse pluse) to activate do same
Jul 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
370 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
