Question about Casio Cameras
EX-Z75 Camera Battery won't charge. Red light flashing
  • 374 Answers
Red light flashing means faulty battery. You need to call tech support and they will replace the battery for you. Just make sure you tell them that it's been under a year since you purchased it. :)
Posted on Sep 13, 2008
SOURCE:
My casio exilim ex-z75 is not working well, I think it may be a problem with the battery. the camera actually doesnt turn on. When I charge the battery, the charger light flashes red. I don't know what...
This often means that the battery is bad. It's a good idea to only charge the battery as long as is necessary, and to then remove the battery shortly after it is finished charging. This helps prevent from an over-charge on the battery which can damage the battery life.
Feb 28, 2011 | Casio Exilim EXZ75 Digital Camera
The battery (NP-20) for my Casio Exilim EX-Z75 is not charging. The light on the charger is continuously flashing red; had for approx 1yr, no prior problems. Please help! I have the exact same problem...
Okay I just fixed this on my camera the same thing. First make sure your battery is charged. You will need to get a paper clip. Take the battery out and unfold the clip so that you can use it to pull up the contacts between the battery positive and negative and the camera. The conductors need to touch the positive and negative on the battery. If you battery is dead you will need to do this as it will not charge your battery on the cradle becaue there was no connection. over time I think that the battery loses its connection and the spring is not strong enough to push up the battery far enough. I ordered a battery charger and new battery and it still didnt work so I started to tinker with it. I held the battery with my finger pushing it up and holding it, and simaltaneuously powered on the camera. Thats when I figured it wasnt the battery but it wa the connection with the battery and the camera.
hope that helps
Apr 27, 2009 | Casio Exilim EX-Z750 Digital Camera
I have had an Exilim EX-Z75 for just over a year. Suddenly I'm having trouble charging the battery. No matter how long I leave it on charge the light keeps flashing and the battery is not charged. Do I...
Yes you need a new battery. I had the same problem almost exactly a year ago. You need to contact Casio and tell them the problem, they should send you a new battery free of charge. This is the proper number to call, 1 800 435 7732. Just tell them your battery charger is flashing red when you are trying to charge and they will send you a new battery.
Feb 21, 2009 | Casio Exilim EX-Z750 Digital Camera
Casio Exilim z75 - unable to take pictures
Try shutting off your flash and see if it still does that. It sounds like you have a problem with your flash not charging correctly. You can try resetting the camera but I doubt if that will help. I would try just shutting the flash off and see if that would help.
Aug 26, 2008 | Casio Exilim EX-Z750 Digital Camera
Exilim EX-Z75 dead battery
Has anyone found a solution to this? I have the same issue!
Jul 14, 2008 | Casio Exilim EX-Z750 Digital Camera
Casio Ex-Z75 Battery not charging ?
This problem is known. There is a way to fix it.
The fact that it blinks on and off means that the battery is completely out of energy. Thus, the charger doesn't "recognize" the battery.
To fix the problem, you need to give some energy to the battery. What I usually do is that I use a 9V battery (or any other source of power) and I link + and - of both the Casio battery and the 9V battery. You can use a paperclip as a link (you will use 2 paperclips, 1 between minuses and 1 between pluses).
Do that for 2 minutes and then charge your battery as usual. It should work !
Sorry if my English isn't accurate. I'm French.
Mar 17, 2008 | Casio Exilim EX-Z750 Digital Camera
Cameras Logo
198 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
