Question about Sony KDSR50XBR1 50" Projection HDTV
My kdsr50 greenish any help thankssssssssss
Thanksssssssssssssssss
  • 23 Answers
Sounds like an optical block issue...
i would suggest google for optical block for this model...
it is fully covered by sony...
good luck
Posted on Oct 01, 2008
Greenish tint
Might try the color tones buttons on T.V. up or down.
Oct 13, 2013 | Samsung LN-S1951W 19 in. LCD Television
My Sony 50" SXRD is flashing 3 red lights by power/standby. I just changed the bulb. What is the problem? Can anyone help please.
According to one site I found, the problem is that the lamp cover was not securely attached. The manual also said the lamp may not be inserted properly. See pages 106 through 108. The manual is located here:
http://www.docs.sony.com/release/KDSR50-60XBR1.pdf
Oct 31, 2012 | Televison & Video
Picture is starting to get greenish, yellowish colored
hitachi model 51f510 projection tv has horizontal lines & has greenish tint,do i need to chang the bulbs??i alredy tryd the magic focus button & manual focus,but unsuccesfl,any ideas????
Nov 27, 2009 | Hitachi 51F510 51" Rear Projection...
Sound driver
go to the compaq website
Jun 27, 2009 | Intel Motherboard
Sony KDSR50 - TV comes on then goes to a black screen - sound is fine. In the 2 or 3 mins of TV visual time, the color looks a bit off - lacking red - could this be a bulb problem? Bulb does not look...
Hi
Its symptom of weak lamp so TV needs new lamp.
Lamp replacement procedure is written in user manual and lamp part number is as follows..
F93087600 Lamp Block XL-5100
Available in Sony Accessories Store, please buy Sony Original Lamp for TV safety.
Jun 26, 2009 | Sony KDSR50XBR1 50" Projection HDTV
My monitor changes to greenish.
First check wether the monitor cable is inserted into the PC and monitor correctly. If that doesn't help, try another cable. If that doesn't fix the problem, please post back here.
Jun 07, 2009 | IBM T 85D Monitor
I have ordered a new lamp...How do I change it out?
The lamp is pretty easy to replace.
You can refer to the owners manual on page 105 and 106.
There is just a door and a couple of screws that hold the lamp in.
Here is a link to the owners manual.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
May 09, 2009 | Televison & Video
Greenish picture when i play my Compaq Ipaq MP3800 projector
The greenish image is due just by one sof the terminals of the cable. You just need to replace it. Or try anothr RGB cable and look what happen.
Nov 18, 2008 | Televison & Video
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
49 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
