Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Where to buy detergent for carpet cleaner and where to get repairs
London drugs sells the detergent for hoover carpet cleaners
Posted on Sep 13, 2008
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
Where can I get a repair manual for a Bissel carpet cleaner model #9400. Prefer a downloadable one.
Only from Bissel, but unless you are a repair shop they will likely not let you buy it.
Jan 25, 2017 | Bissell 9400 ProHeat Upright Wet/Dry...
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
Bissell proheat turbo 2x carpet cleaner
There should be 2 switches one for suction and one to disperse detergent.
Aug 15, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
I have the SAMSUNG WA80V3 washing machine and I have tried many detergents but they all clogg. I also put a filter but still the problem remains. Is it the water quality? I live in Oman.
see the causes and fix it. God bless you
stopped spraying. If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly from
  • Sep 22, 2012 | Samsung CASE-DETERGENT;WA80V3 -...
    Solution for "hoover steam cleaner keeps
    Hoover Carpet Shampooer
    You might just need a new gasket. THey are inexpensive and fairly straight forward to replace with the right tools.
    Sep 10, 2009 | Hoover F7431-900 SteamVac Vacuum
    Instructions on Using The Hoover Steamvac Ultra cleaner
    CARPET CLEANER\r\n™
    i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
    MaxExtract™ technology features the most advanced
    combination of multi-action agitation, carpet washing, dirt
    removal and direct heat drying - all in one machine. This
    technology delivers a floor that is not only deeply cleaned,
    but a room that can be lived in again within hours!
    • High intensity LED
    - illuminates problem areas
    • Stream Setting
    - ideal for smaller spots
    and stains
    • Spray Setting
    - attacks heavy traffic areas
    Dual scrubbing1, multi-directional
    brushes have been specifically
    engineered to surround carpet
    fibers, removing dirt at every angle.
    1Patent pending
    High velocity suction removes both
    dirty water and soap residue, leaving
    carpet revitalized. Forced heat further
    speeds the drying process. No sopping
    wet carpets. No musty odors. Just
    clean carpet.
    STREAM
    SPRAY
    REMOVES MORE DIRT2
    INTEGRATED SPOT CLEANING
    2Test of leading brands of household extractors using FCTP-0024p
    Our exclusive pre-programmed
    cleaning modes take the
    guesswork out of revitalizing your
    carpets. Simply select your carpet
    type and cleaning task, and let
    the pre-programmed modes take
    care of the rest. Fully equipped
    with Process Feedback Lights
    and Full Tank Indicator Lights,
    this Intelligent Cleaning System
    makes cleaning your carpets
    easier than ever before.
    HOOVER PLATINUM COLLECTION™ DETERGENTS
    TO MAXIMIZE CLEANING PERFORMANCE
    PROFESSIONAL STRENGTH
    Carpet and Upholstery Detergent
    PET PLUS
    CARPET CLEANER
    Instant Stain Remover
    Carpet and Upholstery Spray
    AN EFFORTLESS CLEAN
    CONVENIENCE IN HAND
    Powered Scrubbing Tool,
    Upholstery Brush and
    Crevice Tool included for
    cleaning fabric covered
    items such as:
    • Stairs • Upholstery
    • Mattresses • Pillows
    • Area Rugs
    To learn more about the Hoover Platinum Collection™
    visit www.Hoover.com ™ ®
    Six new vacuums, six new standards of clean, and six
    new reasons for Clean Freaks to Rejoice. The Hoover
    Platinum Collection™ saves you time and effort while
    giving you the confidence of knowing your home is truly
    clean. Whether corded or cordless each item is distinctive
    in both appearance and performance, offering best in
    class cleaning through a combination of innovative
    technologies and carefully engineered ergonomic design.
    With the Hoover Platinum Collection™ you get fast and
    effective deep cleaning so you can move on with what
    is next in your day, knowing you have efficiently
    accomplished the deep clean you desire. With these six
    superior cleaners from Hoover®, it is a wonderful time to be
    a Clean Freak, and a terrible time to be a dirt molecule.
    EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
    1.877.MYPLTNM (1.877.697.5866)
    Hoover®’s Best In Class,
    Limited Six Year Warranty
    Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
    All terrain steam vac
    Try and trace the hose back from the brushes to the pump. The hose could either be disconnected, kinked, or clogged.
    Good luck - Tech101
    Jun 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
    Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
    107 people viewed this question
    Top Hoover Vacuums Experts
    Gerry Harvey
    Gerry Harvey
    Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
