Question about Garmin StreetPilot C330 GPS Receiver
Locating Satellites on Garmin C330. Even though I have updated the unit software from the web.
I am sending my unit for repair to Garmin, as it was under warranty.
Posted on Sep 14, 2008
Can't find satellites
Update the device at the Garmin Web-updater
http://www8.garmin.com/products/webupdater/
This can resolve transient GPS problems.
Failing that update the firmware.
http://www8.garmin.com/support/agree.jsp?id=995
Regards
Richard.
Apr 26, 2009 | Garmin StreetPilot i3 GPS Receiver
Cannot acquire satellites and freezes
use the web-updater at garmin
or update the firmware at garmin,
turn WAAS on
turn GPS signal off
go outside after the update
turn GPS signal back on ( takes upto 15 mins to locate satelites )
should be good
Regards
Richard.
Apr 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin_streetpilot_c330_
I was having a problem with my streetpilot about 2 years old - it was not locating satellites quickly. I had to trick it by telling it that the date was wrong when I got the q's for that.
I recently purchased and downloaded the map updates and that solved the problem. The unit locates the satellites in seconds. If you are not having a problem you do not need to purchase the mapupdates but if you are this should fix your problem as it did mine.
Aug 12, 2008 | Garmin StreetPilot C330 GPS Receiver
Abnormal Powerdown Error Code
Your battery is dead, which is causing the problem with "slow to receive satellites". Normally when you turn off the unit it will remember the last location and time, then the next time you start the unit it already has the time and current location to acquire satellites, but with a dead battery it has to start from scratch. Check the screen and see if it says "Locating Satellites" or "Acquiring Satellites". Locating satellites will take longer. Replace the battery and your problems should go away.
Jul 22, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330
Purchase an external antenna from Best Buy or on line from Garmin.
Jun 27, 2008 | Garmin StreetPilot C330 GPS Receiver
New Garmin 330 stuck on kansas
Take the unit outside and turn it on. Then select View Maps, at the top of the screen it will say either "Locating satellites" or "Acquiring Satellites". Once the garmin has locked onto the overhead satellites, then it will say "Ready to Navigate".
Locating Satellites take longer than Acquiring Satellites.
Jun 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Trouble acquiring satellites
Garmin nuvi
will not acquire satellites
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Aquiring satellites
Are you outside with a clear view of the sky? It should find satellites once the unit is turned on. Does it say "Looking for satellites" or "Acquiring satellites"?
If it is "looking for satellites" then it means that the unit have lost all data (time, date, location). If it is "acquiring satellites" then it have date and time, but not location.
Looking for satellites require a longer setup time (could be as much as 15 minutes). Acquiring satellites is much faster (not more than 2 minutes).
Date and time is updated from satellites once the unit gets a satellite lock.
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
No signal
Try and replace the antenna
Aug 11, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
118 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
