Question about Mitsubishi CS-40503 TV
Mitsubishi CS-40503 Horizontal Picture Problems
Hi, we just got a Mitsubishi 40", Model number CS-405503. When you turn the tv on, it displays the full picture, then it displays about 3" to 4" horizontal picture with the top and bottom are black. If you hit the right side, the picture will come back, but then goes back to the small horizontal picture.
Any suggestions??
Thank you...
  • rcmn27 Oct 20, 2008
    we have a Mitsubishi 40", Model number CS-40503. When you turn the tv on, it displays the full picture, then it displays about 3" to 4" appear image black but not complete all monitor, picture with the top and bottom are black. If press the control desappear, but after appear again, the picture will come back, but then goes back to the small horizontal picture.
  • 55 Answers
Your trouble is with the vertical deflection circuitry. You'll need to have it serviced by a professional.
Posted on Jan 17, 2009
Sony TV model # KV-J29 MF8 , sound ok in 1 min and led stdy.and no picture
check for bad voltage regulator ic. Check for 160v across your main cap and power supply. Use floating ground, to see if power supply is working. If you have 160v, check for 130v b+ to see if your horizontal circuit is working.
Nov 27, 2011 | Mitsubishi CS-40503 TV
CS-40503 takes about 10 minutes for the picture to appear once the set is turned on (sound comes on immediately)....when the picture does appear, it's dim for approx. 5 seconds then comes up to full...
IF THIS SET HAS PIP (PICTURE IN PICTURE) THAN I'D SAY THE PIP MODULE IS GOING BAD. YOU CAN REPLACE IT OR GET THE BYPASS PLUG FOR IT. IT JUST PLUGS IN.
Dec 10, 2009 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 TV previously had discoloration in the corners and lines at the top of the screen. Now I have no picture at all. Is it worth trying to fix?
no picture?do you see a white horizontal line in the mid?or black out?
its up to you if its really worth fixing. if its really old then ,i think its time to buy a new one, if not try comparing the cost.
May 18, 2009 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 Zapped by high voltage
the only option is to bring your x-former as sample or take a pic of it and post it.
Mar 26, 2009 | Mitsubishi CS-40503 TV
Narrow blue horizontal line across screen on intial power up
You have trouble with the vertical deflection circuitry. Probably something in the driver circuit or power supply to the driver. Maybe even a cold solder joint since it comes up after a little warmup.
Jan 17, 2009 | Mitsubishi CS-40503 TV
Mitsubishi CS-40503 shuts off while watching.
Could be any number of things, none of them easy to diagnose. Unless your a TV repairman it's probably not worth fixing. It will cost tou more in repairs than a new TV.
Sep 28, 2008 | Mitsubishi CS-40503 TV
Mitsubishi CS 40503
it is repairable and can be fix,,
Jul 30, 2008 | Mitsubishi CS-40503 TV
FORGOT PASSCODE ON TV PARENTAL LOCKOUT
that's a big problem. sometimes using the 0000 can unlock it but it's not 100 percent.try the trial and error.
Apr 19, 2008 | Mitsubishi CS-40503 TV
1995 Mitsubishi 40" Television - Worth Repairing?
there are bad solder connections on the vertical deflection IC resolder them and you will be fine
Mar 13, 2008 | Mitsubishi CS-40503 TV
Weight
I have one of these TVs and still love it.  The manual says that the weight is listed at 250lbs (approx.).  Most of the TV stands in retail stores only hold up to 240lbs., so that is something to consider.
Sep 23, 2007 | Mitsubishi CS-40503 TV
Televison & Video Logo
167 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
