Question about Frigidaire FRS6HR5JSB Side by Side Refrigerator
WHAT IS PLASTIC COIL OF TUBING IN REFRIGERATOR BEHIND VEG DRAWER?
I just had new unit delivered, while un packing we found a coil of plastic tubing behind veg drawer. what is it? it doesn't look like it is going to stay there in normal operation, plumber hasn't come yet to hook up water line so we are curious.
  • 958 Answers
That is the water line that goes out to your water dispenser. it is placed there so that the water that would come out is cold. as if it is the water reservoir.
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
Ice on bottom of freezer floor. Turned off fridge so it could completely thaw. Should I do anything else?
We have the same fridge, we just had the same problem, and followed the instructions found on this website. Probably a clogged drain pipe/tube.
After following these instructions, my husband found a chunk of debris in the tube along with a piece of plastic wire tie that was the probable cause of our issue - here is a copy of what we did last night. (The end of the tube has a little rubbery opening that drips into a pan at the base of the rear of the freezer - the beginning of the tube is behind the grill on the back wall of the freezer, have to put the wire through the grill and into the hole - we put the wire up from the bottom and down from the top to be sure to get the clog)
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
Jul 23, 2015 | Bosch B22CS80SNS (220 cu ft) Side by Side...
Water is not cold
NO SOLUTION, THERE'S JUST NO EXTRA TUBING. Domestic refers with water dispensing feature will have a coil of plastic water tubing tucked away in the refer behind a drawer or at the bottom; it hold s cedent amount of cold water when you dispense it. However, You won't find this additional tubing in a Samsung refer. This fridge is made 'abroad' by folks don't have the same standards as the U.S. The icemaker, for instance, is found to be accepatable by their standards when it makes 72 cubes per day; HAH! We use more than that for dinner. We buy bagged ice and use a Brita pitcher. I will switch back to Whirlpool or Maytag when this thing craps out.
Aug 07, 2012 | Samsung RF265AA Bottom Freezer French Door...
The fan is constantly running and the refrigerator is not cold enough and the freezer is not cold either. all the ice melted and the food thawed. i was out of town for 4 days. returned last night to find...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 27, 2011 | Refrigerators
Both diswashing drawer are running with F1 flashing
We found that the unit was floofing because a thin, white plastic tube behind the drawer had broken. I learned that the plastic tube is to preven the electric cables from kinking when the drawer moves in and out. The broken tube was preventing the seal from working properly and water was getting past it to the bottom of the unit where a water sensor detected it, shut the washer down, and displayed an F1 fault. The simple solution was just to snip the tube off so that it could not reach the lip of the drawer and intefere with the seal.
Jan 13, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
My water from the refrigerator door is coming out warm . The freezer and main frige are normal ... what could be causing this ? A prelude for something going wrong in the near future perhaps ?
Check to see if all the tubing for the water line is coiled inside the refrigerator, often times with moving objects things become lose and tubing gets moved around as well. When my refrigerator did this the tubing was some how laying against the motor and thus causing the water to be warm. The tubing which is incredibly long is usually located behind the fruit/veggie drawers which is also (in my refrigerator) is located right behind those drawers if the tubing is laying against those bulbs this could also be the cause of the warm water.
Dec 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
There is an ice build-up underneath the humidity control drawers and the food in the drawers is freezing. It is a model RB 215 LABB. We have adjusted the temperatures of both the freezer and the fridge,...
The problem isn't the humidity control or temperature control. When the refrigerator automatically defrosts it goes through a cycle of heating and melting the ice build-up then drains this water to a tray at the bottom of the refrigerator (underneath). The drain tube that lets this water flow down to the bottom tray freezes so the ice begins to build inside the refrigerator section.
The solution to this is to defrost the tube so water can flow again. There are heating coils in the freezer section behind the plastic in the back that you must remove and defrost.
This is an inherent problem with a lot of refrigerator/freezers. You should probably have your refrigerator serviced and to check the heating capability of the coils to keep this tube from freezing. Otherwise put this on your monthly schedule of manually defrosting.
Sep 23, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Slow leak in refrig. coolant tubes.
If that doesn't work go to an appliance repair parts store or HD buy about 10 ft of plastic tubing coil up and use it to replace the tank. Alot of the newer models use this instead of a tank.
Jan 29, 2008 | GE PSI23MGN Side by Side Refrigerator
Ice maker is not functioning
sounds like a frozen fill tube, easy to check pull out refrig and you see plstic tub running into top of freezer section from behind, sometimes theres a connector fitting half way up the tube, if not you have to cut tubing and install a coupling to repair cut(available at any harware store)after cutiin tube try blowin throughin to freezer, if you cant its frozen,un freezing somtimes challange, sometimes able to blow straight though the ice other timesi se hair dryer (from iside freezer where fills the ice maker itself. best way ive found is using my steam machine i bought from one of the infomercial.good luck!!!
Jan 01, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidaire FRS6HR5JSB Side by Side Refrigerator Logo
275 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
