Question about HP Office Equipment & Supplies
I have a D4260 printer. I have connected it to my laptop as instructed but I cannot get it to print. I get no response at all.
    Genius:
  • 1,550 Answers
Likelihood of Communications errors. Check all the cables for secure connection(they do come out sometimes, for no reason). Also, make sure that you have the most current drivers from the makers website.
SAM ANDERSON
Posted on Sep 13, 2008
My hp deskjet printer d4260 is not printing when i send i print job to it
if you have updated drivers from HP, Uninstall them, and install the drivers from the original CD that came with the printer. the updated drivers from HP don't work well with Windows 7.
Feb 27, 2011 | HP Deskjet D4260 Printer
Hi ! When I install my HP product I get at connecting my HP print but I don`t know what to do. Please help me.
If you connect your hp printer to the computer, it should install the basic drivers available from the Internet, which hopefully will be automatic. If it doesn't install automatically, then you'll have to manually download the correct driver for the hp deskjet d4260 inkjet printer.
In most cases, the printer will be connected physically with a usb cable. One end goes to the back of the printer, and the other goes to the back of the PC.
Good luck on this.
Jan 01, 2011 | HP Deskjet D4260 InkJet Printer
When I try to print with my HP D4260 printer, it will not print solid colors - everything has banded lines. Can I fix this?
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP Deskjet D4260 Printer
How do I stop my HO Deskjet D4260 from printing?
unplug printer first then in the printer Que delete all jobs and check that the last file you tried to print is not corrupt and printer driver is not corrupt restart pc and then it should ok when you power up pc and printer
Oct 11, 2010 | HP Deskjet D4260 Printer
Hi , my printer hp deskjet d4260 does not print. There is ink and paper in the printer but whenever i try to print something it doesnt work. When i did chang the ink it still printed the paper for...
1. goto control panel -> printers.
2. delete the unnecessary printers including your D4260.
3. Use the driver cd which came along with your printer and reinstall all the software and drivers again.
4. Now you should be able to print without any problem because in this way all the driver conflict or corrupt printer files will be fixed.
I hope this is helpful to you
thanks
Sep 23, 2010 | HP Deskjet D4260 Printer
How do you clean print heads on hp deskjet d4260? I refilled my cartridge and now it prints steaky and light.
Go into the software that came with it, and use the cleaning cycle program. This will solve it for you.
Jul 16, 2010 | HP Deskjet D4260 Printer
I HAVE A D4260 DESKJET PRINTER THE RESUME LIGHT IS CONSTANTLY FLASHING IT HAS PAPER BUT WONT PRINT A THING HEEELLLPPP!!!!
if light is constantly flashing, printer is not print.
printer on and all papers out in printer and light is always on than paper in and print.
Mar 01, 2010 | HP Deskjet D4260 Printer
Printer will not print anything
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
PREM
Feb 20, 2009 | HP Deskjet D4260 Printer
Will not print anything?
Check the cartridges first
Try doing this
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Jan 28, 2009 | HP Deskjet D4260 Printer
Printer won't print
HI
Try to unplug the printer and then plug it back
Jan 27, 2009 | HP Deskjet D4260 Printer
Ben Johnson
