I have a uni wash industrial washing machine and the display shows water .. any ideas
    Genius:
  • 1,239 Answers
Hi it is a water sensor problem......check it
Posted on Sep 13, 2008
We have moved house and plumbed in our machine and code 5E has come up Any ideas what is going wrong and how to fix it
The '5E' Error is displayed when the water is not draining properly from the Washing Machine. If the water does not drain in 15 minutes, a buzzer will sound , and the remaining time indicator will show '5E' Error. You can perform following steps to resolve the issue : Clean the debris filter.
Jul 13, 2017 | Samsung Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Unimac. Why is it displaying E FL and won't spin?
    Unimac Washer Product Support ' ManualsOnline.com
    laundry.manualsonline.com/support/unimac/washer/
    Unimac Washer uw60b20u80001. 0 Solutions ... on start up unlock door light stays on.display sa. Unimac ... washer has falt code E FL what does this mean and.
    E fl error code on industrial uni Mac washer. What's it mean ...
    www.fixya.com/support/t20744713-e_fl_error_code_industrial_uni_mac
    Jan 07, 2016 | Washing Machines
    Unimac front loader washer with the error code OF not sure what it means. This is a stackable unit.
    [PDF]Operation/Maintenance for Drying Tumblers - Alliance ...
    docs.alliancelaundry.com/tech_pdf/Production/70283501en.pdf
    NFPA 54 "National Fuel Gas Code" and Standard ANSI/NFPA 70 "National Electric Code." In Canada ..... NOTE: If display shows an error code, refer to.
    Oct 15, 2013 - I've had this issue three times. On the first case, I found my external drain hose ( the hose from your washing machine to the drain in your wall) was ...
    65 lb Capacity UWN065T4V - UniMac
    unimac.com/products/unimac-washer.../high.../65-lb-capacity.aspx
    A description for this result is not available because of this site's robots.txt - learn more.
    e OP error - YouTube
    Dec 15, 2015 | Washing Machines
    E fl error code on industrial uni Mac washer. What's it mean?
    try to remove the drain pump and clean,theres something inside that destruct the operation of the pump.ppm must be done in every equipment,thanks.
    Oct 15, 2013 | Washing Machines
    H20 is showing on the display screen of my hotpoint washing machine. I'm aware this means water but I'm wondering why this is displayed?
    Possible that there is no INLET pressure or water flow to the machine, check the inlet filter and valve, check for good flow to the valve if the hose is disconnected. If not it needs to be checked if the panel board is showing error due to memory fault..
    Jan 23, 2013 | Washing Machines
    Water not coming inside the washing machine
    Water not coming inside solutions:
    1. Make sure the inlet has water or the faucet going into the washing machine inlet has free flowing water.
    2. Did you turn on the machine on?. This is required specially for heavy duty 10kg Whirlpool industrial grade washing machines..
    3. If the two above didnt work. Try rotating the knob to NORMAL and pull it.
    4. Contact the nearest Whirlpool service center for repair if problem persists.
    Hope this helps
    levibit
    Dec 13, 2010 | Whirlpool Washing Machines
    I have a samsung washing machine wf7600naw washing machine that won't spin and is displaying the error code SE. How can I fix the problem?
    WATER DRAIN ERROR - Display shows 5E.
    5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
    Dec 11, 2010 | Samsung Washing Machines
    Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
    Here is a list of errors for your machine.
    I hope they help you.
    SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
    When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
    1. WATER SUPPLY ERROR - Display shows 4E.
    Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
    2. WATER DRAIN ERROR - Display shows 5E.
    3. OVER-FLOW ERROR - Display shows oE.
    Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
    4. UNBALANCE ERROR - Display shows UE.
    Laundry load is unbalanced, manually loosen any tangled laundry.
    If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
    5. WATER HEATER ERROR - Display shows HE, HE1.
    HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
    6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
    * Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
    Normal Level = Abnormal W/L Frequency
    Low Level = 30.00 Khz
    High Level = 15.00 Khz
    If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
    7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
    e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
    At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
    8. WATER LEAKAGE ERROR - Display shows 11 E.
    Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
    9. THERMISTOR ERROR - Display shows tE
    Nov 21, 2010 | Washing Machines
    Washing machine stops and flashes 4E
    1. WATER SUPPLY ERROR – Display shows 4E.
    Feb 23, 2010 | Washing Machines
    Washing Machines Logo
    48 people viewed this question
    Top Washing Machines Experts
