Question about GE Washing Machines
Front end loader washer Model 300GWW Strong odor in washed clothing. towels, etc. Routinely clean inside surfaces of door rubber seal. Using 2X Ultra Tide (he)detergent. Please advise recommendations to eliminate odor.
  • GE Master
  • 5,568 Answers
I don't know how frequently it is used but if it is not draining completely, the residual water may be going bad. This is much more likely if using well-water than with municipal water. The former does not have any chlorine in it.
You might try (once) to 'wash' nothing first; let the machine cycle with no load and then with load to see it if makes any difference. If it does, then either have the machine checked by a tech or dump a 1/4 cup (or less) of bleach in the machine after emptying. If it is simply water going sour, the bleach will prevent it turning skunk-like.
Posted on Sep 13, 2008
My Neptune washer leaves an odor in my clothes
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!^^^
Jun 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Tip
Getting Rid of Front Loader Mildew and Odor
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
USE HE DETERGENT ONLY. Using regular detergent, or improper amounts of detergent can contribute to the build up of soap scum in which dirt can collect. Regular detergent is formulated to be used in a conventional wash tub with capacity of about 35 gallons. A high efficiency front loader only uses 5 to 7 gallons of water. So, if you use regular detergent in a front loader, you are, in affect, using about 5 times the concentration of detergent needed. This can cause oversudsing, premature wear on the pump motor and parts, premature wear on rubber seals, odor from sticky soap residue and skin irritations caused by soap residue left in clothing. Using improper detergent will also void the manufacturer's warranty. Make sure you READ all detergent labels some HE detergent is double (2X) and triple (3X) concentrated.
I hope this information is found to be helpful.
on Dec 09, 2009 | Washing Machines
Washer Odors of Mildew
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Stale odor within tub
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Dec 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stale odor in machine and on towels and clothes. I have used the affresh, Bleach, baking soda, use powder HE detergent, no liquid fab softner, I am at the end of my rope with this stinking machine ready to...
Towel mildew smell is being transferred from the washer. The washer must be cleaned first. The problem is not "brand specific" all clothes washers have mold growth to a certain degree. Bleach or vinegar will kill the mold inside your washer but won't remove it or the residue it grows on thereby making the situation worse because it leaves a "base" for more detergent to collect on and more mold will grow.
Washing machine mold / mildew odor is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Smelly towels
First do this: Start a normal cycle with no clothes in the washer. After the washer agitates (tumbles) a few minutes, pause the washer and look immediately if there are any suds in the machine. There should be no suds what so ever. If you see any, that means there is a build up of soap residue in your washer. That would be caused by an excessive amount of soap usage. You did not say how much soap you have been using. For a large load, use 1 to 2 tablespoons of soap at most (even less if it is 2X or 3X concentrate) and not more than 1 teaspoon of fabric softener if you use it. This is due to the fact that your machine is only using about 12 gallons of water, vs about 45 for your old top load machine. Your towels have soap residue left in them. Wash with no soap for at least one time. If you are doing only bath towels, and towels are used only to dry off your clean body after your shower, they are not dirty, just damp. They do not really need soap to clean them. (and remember to never use fabric softener with towels)
You did not state your model number, but I believe you have a tub clean cycle on it. Run that cycle with no clothes and a front load washer cleaner in it, such as 3 tables of Affresh, or a full bottle of Washer Magic, or Tide front load washer cleaner, or Whirlaway hot tub cleaner, or Smelly Washer Cleaner (smellywasher.com).
I have also heard some people have had better luck with powdered soap, but I think that the amount of soap being used is really your problem
Jun 14, 2009 | Washing Machines
LG washing machine has AWFUL mildew smell
I have an LG washer that had the same problem. Go to the site www.nufreshnow.com and read all about why this is happening, how to fix it and how to keep it from comming back. A few different ways of cleaning the machine are explained.
The site sells a product that you may or may not need but the explanations are really good.
Nov 12, 2008 | Washing Machines
Mildew smell on cloths
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
If your washer is a LG WM-1832 it has a assessable filter behind the access door on the lower left front of the machine. Clean that out first, and if it has a tub clean or sanitary cycle use that cycle (if not, use hottest longest cycle available) with 3 Affresh tablets or use whirlaway to clean out the washer outer tub (the not visible tub that holds the water). You might want to use another cycle like that with bleach to head off mold or mildew growth. Use of proper amount of detergent and fabric softener should really help the clothes odor issue from then on. Also check the tub seal at the bottom of the door area to clean out any lint from drain hole areas to help prevent water from remaining in the tub seal area.
Oct 28, 2008 | LG WM-1832C Front Load Washer
Odors on the clothes after washing in Maytag front loader
Oct 23, 2008 | Maytag EPIC MFW9700S Front Load Washer
Stinky towels
Mildew odor in towels in almost invariably being transferred from the washing machine. The clothes washer must be cleaned first then clean the smelly towels and laundry. To compare washer cleaners watch this video of Affresh and Smelly Washer...
http://www.youtube.com/watch?v=Ua6OJPn0-fU
Apr 19, 2008 | Washing Machines
Washing Machines Logo
78 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
