How do i connect a linksys wag200 to cable - Computers & Internet
Many ppl think they're experts, but do they really are?!?!
The knowledge and wisdom is found through reading, reviewing, and learning.
However, many ppl just copy and paste the solutions from webpages.
Posted on Sep 21, 2008
  • 1,879 Answers
Most cable Internet Service Providers (ISP) use a Media Access Control (MAC) Authentication to establish Internet connections for end-users. A MAC address is assigned a unique 48-bit (6-byte) integer that is attached to an Ethernet NIC for each computer. To set-up your Linksys gateway to a Cable ISP, you have to do MAC Cloning. MAC Cloning is a procedure which enables a gateway to copy the MAC Address of the PC that’s registered with the ISP.
To setup a Linksys gateway with Cable connection you need to perform five steps:
  1. Verifying Internet Connection
  2. Connecting Devices Together
  3. Checking the Gateway’s LEDs
  4. Configuring a Linksys Gateway for a Cable Connection
  5. Power Cycling
More detailed information can be found from the Linksys website
Posted on Sep 13, 2008
Sudden shut down
It's possible that this is a hardware failure or a power adapter failure. Try to reset the unit and reinstall it again. You can also check for firmware updates available online. Try to use other power adapter as well with the same specs with the original power adapter.
Jan 25, 2014 | Linksys Computers & Internet
Can't connect to the internet
If your Linksys is setup correctly it may be your computer? Verify ALL cables/connections to and from the Linksys. Have you verified, with a Ethernet cable, from the Linksys to the computer, the you can connect? We want to eliminated the possible issues, If you can connect using a Ethernet cable , we know the Linksys is setup properly. Then we move to the computer. I need the Make, Model of computer and the OS you are using.
Dec 27, 2012 | Cisco Linksys EA6500 Smart Wi-Fi Dual-Band...
Need to hard reset my WAG200G to connect to VPN
You will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.
Jul 27, 2012 | Linksys Wag200g Wireless-g Adsl Gateway...
I have done a hard reset for my router, I tried the suport page but it did not help... I want to know the default username & password.
To access the web-based utility, launch the web browser on your computer, and enter the Gateway's default IP address, 192.168.1.1, in the Address field. Then, press Enter.
A login screen appears. Use the default user name and password, admin, unless you have changed them during the Setup Wizard. (You can set a new user name and password from the Administration tab's Management screen.) Click OK to continue.
You may refer to WAG200 User Guide if required. (Page-5&7)
Feel free to contract me for further assistance
Hope it helps! Good Luck!
CreativeTECH
Feb 14, 2011 | Linksys WAG200G Router
I want to connect a Scientific-Atlanta WebSTAR 2000 series Cable Modem to a Linksys Wireless-G WRT54G wireless router but the linksys doesnt detect the modem and the computer wont let the setup program for...
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer that's registered with the ISP.
To setup a Linksys router with Cable connection you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting Devices Together
iii. Checking the Router's LEDs
iv. Configuring a Linksys Router for a Cable Internet Connection
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G WRT54G Router
Can connect to internet directly through modem. When connected through Linksys WRT54GS router, all lights are ok on both modem and Linksys--including internet. (Have had this router for 2 years...no...
As last resort you might want to use a JTAG cable and debricking programming software. If your router is brikced or you want to change the firmware this cable can do it. The cable will connect to your parallel port and your wireless router so you can repair your router. They are about $5.95.
Jan 11, 2010 | Linksys Wireless-G WRT54G Router
Linksys wrt54g SRX200. I can connect to my router
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
Dec 19, 2009 | Linksys Wireless-G WRT54G Router
Linksys WAG200G doesn't have a green light with the internet.
Try unplugging the WAG200 ADSL Home Gateway, leave it off for a minute, then plug it back in. Sounds too simple, but it works more than half the time.
Apr 14, 2009 | Linksys WAG200G Router
Linksys wireless-g broadband is not hook up to comp. the cord from cable modem the by pass is on to the comp.
If you want to use the linksys, you need to connect the cable from the modem to the linksys, then use another cable to connect the computer to the linksys. If it does not work, call linksys technical support, if they cannot help try this http://technicalsupport.blog.friendster.com
Feb 18, 2009 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
