Question about Mitsubishi WS-65809 65" Rear Projection Television
MITSIBUSHI WS65809 TV
I RECENTLY PUT A HIGHVOLTAGE BLOCK INTO MY WS65809 BECAUSE OLD ONE WAS ARCHING,I PUT IT IN AND STILL NO PICTURE I HAVE SOUND BUT WILL NOT WORK???ANY IDEAS TO GET ME PICKIN AT MY BRAIN???tHANKS GLENN
  • 3 more comments
  • TRAVLINMAN80 Sep 16, 2008
    HI BIG IRSH NO SOLDER WAS INVOLVED WITH IT U PUSH IN THE ENDS INTO THE HIGH VOLTAGE BLOCK THE SAME WAY I TOOK IT OUT,THE OLD ONE WAS ARCHING FOR SOME REASON I HAVE NO IDEA.THE AUDIO I GET IS FROM TV NOT STEREO.SOME GUY TOLD ME TO GROUND OUT THE PICTURE TUBES UNTIL I HEAR A POPPING NOISE AND SHOULD FIX IT BUT I HAVE NO IDEA WHERE TO PUT IT ON PICTURE TUBE????????????????????????ANOTHER THING IS THAT I DONT HAVE ANY TESTING EQUIPMENT EITHER?????ANY SOLUTIONS LET ME KNOW U HAVE A PHONE???IF U WANT I COULD CALL U AND MAYBE GO OVER THIS WITH U ITS UP TO YA NEED TV BAD??THANKS GLENN
  • TRAVLINMAN80 Sep 17, 2008
    HOW DO I DO THIS?????I MEAN UNPLUG THE WIRE THAT COMES FROM TRANSFORMER AND GOES INTO THE" IN" HOLE ON HIGH VOLTAGE BLOCK.???THEN WHAT UNPLUG THE OTHER WIRES THAT SAY OUT ON HIGH VOLTAGE BLOCK ONE AT A TIME??????IS THIS SAFE AS LONG AS I DONT TOUCH WIRE ENDS JUST THE PLASTIC AREA?????????????????????LET ME KNOW CAUSE I WANT TO RULE OUT ANYTHING ELSE THAT I DONT NEED TO FOCUS ON????????THANKS FOR GETTIN BACK TO ME CAN I CALL U OR U CALL ME???????????????????LET ME KNOW?????THANKS GLENN
    BIG IRISH ANOTHER THING I SHOULD NOTE IS THAT I JUST TRIED MOVIN THE WIRES AROUND AND PUSHING THEM IN TIGHTER BUT NO LUCK,THERE IS A LOW PITCH HISSING SOUND COMING FROM HIGHVLOTAGE BLOCK WHEN I PUT MY HAND NEAR THE SIDE OF IT I CAN FEEL AIR COMING FROM IT AND IF MY FINGER GETS CLOSE ENOGH TO TO WHERE THE IN WIRE GOES INTO IT AN ARCH SHOOTS INTO THE HOLE A SOLID ONE????WHAT THE HELL IS GOIN ON?????U HAVE ANY IDE???HELP?????????????????????????????????THANKS GLENN
  • TRAVLINMAN80 Sep 20, 2008
    BIG IRISH U OUT THERE MATE????????????????
    YES IT DOES HAVE A PLUG ON IT IT AS 3 PINS AND THAT IS TIGHT I CHECKED ALL THAT STUFF??????????????????????????????U THINK I SHOULD GROUND OUT THE PICTURE TUBES UNTIL I HEAR A POPPING NOISE...SOME TECH TOLD ME TO DO THAT BUT WHERE DO I PUT WIRE ON PICTURE TUBE?????????????????.ALSO EVERYTHING IS WIRED RIGHT???
  • 927 Answers
Good Day, GLENN;
I assume that IHVT was arcing from the side, and the audio is from the TV and not stereo? Or was it the high voltage splitter? Was it plug in or soldered IN? It sounds like you may have bridged a solder joint, unplugged something by accident or something else? Double check your work first of all. Do you still get high voltage? You may poor part. Good Luck, big IRISH.
Posted on Sep 16, 2008
  • MICHAEL MULLINS Sep 16, 2008
    Good Day, Glenn;
    The High Voltage Splitter you replaced should have four large wires, disconnect the short one first, from the IHVT, it's near Splitter. See if you High Voltage. Since it was arching you should have high voltage. CAUTION there is about 35 KV there.
    Now if you do not the problem is before the IHVT. Back to if you do have voltage, disconnect each other lead separately until TV comes on. Good Luck, big IRISH.
  • MICHAEL MULLINS Sep 20, 2008
    Good Day;
    It sounds like you have a bad part or you may wired it wrong. Does not this part have a plug on the bottom? Is that grounding plug properly seated or plugged in? Let me know, big IRISH.
Vizio e420-a0 has no picture
the problem isnt in the power supply unit, put back the original power supply instead, check the heat section of the board where you can see the flyback section, verify the high voltage input by using the voltmeter , if high voltage is missing check all the capacitors and diodes near the highvoltage section, if blown replace it with the same value.
Nov 29, 2016 | Vizio Televison & Video
Phips TV -- No picture -- Only sound & power
Its a power supply issue.The only solution to fix this up is to get it repaired.
Goodluck..
May 01, 2008 | Televison & Video
BN44-00289B
Sound like you might have a high voltage ribbon going to the picture module arching. Turn the Volume down and put your ear close to the edge of the set and see if you heard a arching or a high frequency pitch coming from the side or top..
Gillight
Dec 07, 2013 | Samsung LN46C650 TV
My Toshiba RD-85DTSB has recently developed a buzzing both during playback of programmes recorded before the problem developed, or just when you are watching the TV through the DVD recorder. It is not the...
Hello
Ensure that ur AV cord is plugged in properly into the Audio Video outlet on the back of your tv.If this does not solve the problem then the buzzing sound u hear is that of theFBT-the Highvoltage Flyback Transformer 100% already dead also other possible components on the Highvoltage Deflection circuitries are dead too.
The TV must be troubleshoot by a qualify tv Tech.This tv is not going to be cheap to troubleshoot and repair by a Tv tech.The FBT alone replacement alone,will cost u like $200 already
Jun 28, 2011 | Televison & Video
My tv will turn on and stay on for about 2 minutes, then it will turn off. Any suggestions if this could be repaired?
Tv have picture and sound within that 2 minutes?Yes,than tv have coldsolder joints some where just resolder the video board connections pins hole socket of the video board connected to the tv CRT-tv tube.The FBT resolder it too.The big black block of plastic witth a red wire with a cap hook up to the CRT-tv tube.U just require a soldering iron and a roll of solders and know how to do basic soldering?Most of the times just require resoldering for FBT-for stronger highvoltage output for the Flyback transformer.The video board CRT-tv tube sockets pins in the connected them both,will solved the problems.
Jan 21, 2011 | Sansui DTV2760 27" TV
5 year old synphonic 37 inch (regular) TV has recently started making humming/buzzing sound similar to when reception is weak (picture is clear). TV is connected to cable and none of other TV's have...
Open the cabinet of the tv,on the FBT,the big black block of plastic with a red wire with a cap to the CRT tv tube.Near the base of that big black block of plastic have a 3' steel rot on the block,glue that with some super glue,will solften the noise alot or stop it all together
Mar 08, 2010 | Televison & Video
TV picture won't come on
highvoltage is not coming on
Jul 27, 2009 | GE 35GT740 35" TV
Electrical Arching in back of tv
Check the connection of the ground. Bad connection of ground usually create this problem.
Especially the ground connection between the crt board and the wire who surround the picture tube. Let me know what you will get after this.
Sep 24, 2008 | Polaroid TTM-2401 TV
Arching in Picture tube socket
ok! the arching line is for screen grid, make sure your spark gap is in align! or much better replace a new one CRT socket then clean all CRT board area with laquer thinner...
Sep 26, 2007 | Televison & Video
Mitsubishi WS-65809 65" Rear Projection Television Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
