Frigidaire GLWS1233A Top Load Washer
Problem for Frigidaire GLWS1233A Top Load Washer
Washer
By coleen on May 22, 2006
hi my washer was making a lot of noise last night now it wont spin at all is my belt broke or just loose?
Same Problem
May 09, 2008
-   my washing machine will not spin-   janlake
Mar 14, 2008
-   my wash will spin but makes a loud noisy like its hitting the inside walls-   Guest
Mar 07, 2008
-   how do you put the drive belt back onto the washing machine it seems too small to get over the drum and the small spindle at the bottom-   danieljermyn
Best Solution
posted on May 22, 2006
Helpful)
dovi
Rank: Guru  Washers & Dryers  Expert
Rating: 88%, 2523 votes
It doesn't look like a belt problem, it "sound" more than a problem with the transmition between the drive motor and the inner tub.
Another direction - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining.
Good luck !
Was this helpful?
Yes
No
Solution #2
Helpful)
catriver
Rank: Guru  Frigidaire Washers & Dryers  Expert
Rating: 94%, 3228 votes
Coleen, you can get a visual on the belt by removing the two bottom screws on the front panel and pulling down a little on it and pulling it out from the bottom. There will be two clips that hold it on the top. Make sure your lid switch is operative first of all. After you have the front panel off, put it into spin and see what happens. If the belt seems to be o.k., there could be other problems. One of them would be the transmission itself. You do have a five year warranty on the trans..parts only. You could have something in the pump which would cause the motor to bind and not turn the trans. Or you could have something between the basket and tub causing your problem. Truley hope this helps..
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
bmwrider
Rank: Wiz
Rating: 84%, 1903 votes
The noise could've been caused gy the machine being out of plumb or badly loaded (too much load on one side.
The fact that it would cause the machine to jump around could mean your belt has simply fallen off.
Does it sound as if the motor is still working. If it doesn't it could mean the machine needs a reset. Somewhere on the back should be a plastic button to reset the electronics.
It would be a lot easier to see the machine but I don't do house calls :-)
Was this helpful?
Yes
No
Solution #4
posted on Mar 28, 2007
Not Rated)
Guest
Rank: Apprentice  Washers & Dryers  Expert
Rating: 0%, 0 votes
it would be nice if people would forget about bad loads or adjusting a load, uusually if a wash machine is making noise and now it won't spin, there is probably something alot more wrong then the load, thanks for nothing, bm
Popular Solutions for Frigidaire GLWS1233A Top Load
Questions and Unsolved Problems for Frigidaire GLWS1233A Top Load
Do you recommend Frigidaire GLWS1233A Top Load Washer?
Answer
Answer
fill with water, won't agitate, will spin and drain.
Answer
My Frigidaire front load won't stop filling with water?
Answer
String caught in drum. Tangled. Got lid off, and ring off, but the string goes down between 2 drum... (More)
Answer
During the wash cycle the washer was making a clunking noise. Then the agitator stopped and you can... (More)
Answer
I bought a used frigidaire top load washer Model GLWS1233AS1 about 3 months ago. After it fills, the... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Baltimore, MD
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
