hi
This control panel switch regulates the temperature of the water in the tub. It also plays a role in controlling the fill cycle. If you suspect this switch is faulty, remove it and take it to a professional service person for testing (the test takes special equipment). Or, hook a test wire across the switch terminals; if water flows, the switch is faulty. If the switch is faulty, replace it with a new one of the same type. Connect the new switch the same way the old one was connected. If there's a problem with both water temperature and tub filling cycles, both the temperature switch and the timer may be faulty. Test both components and replace them as necessary. Procedures for testing the timer can be found below.
Was this helpful?
Yes
No
Popular Solutions for Candy CN126 Front Load Washer
It is not a new machine but was working very well so far. It is still working but while it is...
(More)
It is not a new machine but was working very well so far. It is still working but while it is working making a noise something like stuck inside then when the washing up finished clothes smell badly. Do you know what would be wrong with the machine? If it will cost me too much to get it repaired then I can may be buy a new one! Thank you
how do i take the filter out of my washer as it seems to be stuck!! do i gust turn it anti...
(More)
how do i take the filter out of my washer as it seems to be stuck!! do i gust turn it anti clockwise??? please help
