Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Model number: KSRB25FHSS05
i woke up this morning to a puddle of water....the freezer has defrosted everything!!! i asked around and got the insight that it might be the icemaker...and recently the icemaker would not work as well and would not really dispense alot of ice and now its nothing but a puddle! what do i do!?
  • 943 Answers
Hi .thanks for the question .is the fridge on, is it running. if not. it could be in defrost mode .if it is running .pull freezer from the wall, remove back panel ,clean all coils. thanks the appliance doc
Posted on Oct 05, 2008
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
Went of vacation and just returned to a puddle of
your ptc relay and contactor on the compressor body is defective,unplug the unit,remove the spring wire or clip that holds it onto the compressor and install a new one,also if it has a run capacitor replace this also
Mar 18, 2010 | Freezers
Puddles of water in the fridge
OK that sounds like Ice may be blocking the defrost condensate drain. I will need your model number to help me to identify your model better but can leave you with some information about water leaking inside the freezer or fresh food compartment. Sears use a model number found around your door frame and looks like this for example 312.56989 Be right back with some links, Thanks Sea Breeze
Feb 19, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
My GE side by side refrigerator is leaving a puddle on the floor in the morning. There is also a frozen puddle on the bottom of the freezer. What might be wrong?
You will need to remove the bottom freezer crisper and check the defrost drain , to see if it is iced over . If so , then use a hairdryer to melt the ice ( hot water also helps ) . When you see the drain , ( could be obvious obstruction from plastic ) , use a small hose inserted into the hole , to blow thru , to remove any unseen debris blockage .
You may have to remove the rear inside freezer panel to access this drain , depending on your model number .
Oct 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice buildup in bottom of freezer--puddle of water on floor
this sounds like your freezer is operating properly, except that the drainage of the water when going through the defrosting mode is not draining properly, pooling on the bottom of the freezer and then freezing. Check the drainage hose for the defrost in the lower pan. I would remove everything, place in ice chest, let the unit completely thaw out and then inspect. I hope this is beneficial.
Aug 05, 2009 | Freezers
Freezer stopped freezing...Frigidaire Side by side PLHS267ZAB6
Oh dear. I think you need to find helpful neighbours to keep things frozen while ths is sorted out.
If the compressor is still running, there can be 2 causes for this.
#1 The compressor is not pumping, but vibrating (making more of a buzzing sound than normal).
This is a realatively quick fix needing just a component replacement.
#2 The refrigerant gas has escaped, so there is nothing to pump.
This is usually impossible to repair on domestic models due to construction methods.
If the compresor is just running normally, then this is what's happened I'm afraid.
Hopefully this information will assist you to take the right action.
A rating of Fixya is usually given for accurate concise information, with helpful and thanks given to partial solutions.
Thank you for using Fixya!
Jul 03, 2008 | Refrigerators
Refrigerator consisently buzzing...freezer defrosted overnight
Not enough information to correctly offer , a diagnosis but, a buzzing sound could mean the compressor is attempting to start but can't. or it is running without freon. You will need a diagnosis from a certified technician for this issue.
Oct 18, 2017 | Refrigerators
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
174 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
