Question about Frigidaire GLWS1233A Top Load Washer
My frigidare glws1233a top load
HELP MY WASHER IS MAKING ALOT OF NOISE WHILE SPINNING ONLY,AND ITS NOT OFF BALANCED! I JUST BAUGHT THIS MACHINE A WEEK AGO USED OF COURSE PLEASE HELP ME
Mine was doing the same thing. I took off the top (remove the two screws underneath the panel strip under the controls, then lift from the front using a putty knife to push in the two clips) and removed the agitator (bolt in top under softener cup. On the agitator shaft is a collar with two bolts through it. One of mine was missing. The washer made a huge racket when spinning and would go out of balance easy empty or full.
Posted on Aug 17, 2007
  • 641 Answers
Do you have this noise when operating an empty machine ? It could be cause an unbalanced load of clothes. Stop the machine, redistribute the clothes and re-start the machine. In case you still have this noise, the problem is with the transmition between the drive motor and the inner tub. Good luck !
Posted on May 22, 2006
Why is my fridgidaire top loading washer so loud?
You didn't say when it was making the loud noise. During the wash cycle or spin cycle? An unbalanced washer will make a loud racket, too many clothes or actually not enough will make the basket bang around in there. If it has a center agitator, make sure it is tightened down. The screw is under the center Fabric Softener cup. That's the easy stuff to check. Now on mine, when you take the front panel off, I noticed that the hooks and springs that hold the basket up & in place and help keep it balanced, had actually over time had worn the round holes in the metal construction of the machine to oblong holes. Not much you can do about that. If the noise is coming from the motor, & you can't find a used cheap one, it would be more cost efficient to just use as long as you can and buy another machine. A loud noise could also be caused by a bad pulley. Hope this helps.
Jul 03, 2014 | Frigidaire GLWS1233A Top Load Washer
MY FRIGIDARE INFINITY WASHER STOPPED SPINNING AT ANY CYCLE...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2011 | Whirlpool GHW9200L Front Load Washer
Frigidare washer, model LST6000ESO will not spin water out of the clothes.
heatman101
Jun 25, 2011 | Frigidaire Washing Machines
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
Washer won't spin making a humming noise
heatman101
Sep 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Very loud banging noise when front load washing machine spinnning
Ensure that the appliance is balanced/level on the floor. Contact an appliance service company.
Feb 22, 2010 | Kenmore HE2 Plus Front Load Washer
Maytag top load washer making a loud noise when spinning
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 17, 2009 | Washing Machines
In the rinse cycle the washer is making a squeeking noise
check whether there is something inside the washing drum ..
by mistake some thing might have fallen inside..
else the bearings would have worn out making the squeeking noise..
thankyou..
Mar 13, 2008 | Frigidaire GLWS1233A Top Load Washer
check to make sure you have removed all the shipping braces
Mar 02, 2008 | Washing Machines
Frigidaire GLWS1233A Top Load Washer Logo
240 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
