I'm trying to connect to a ftp server of a company who gave me the user name and password. They gave me step by step directions. However, after I successfully enter my user name and password - no page opens where I can drag & drop my files. I have Windows XP and am using IE7. Thanks for your help
  • 1,879 Answers
What happened to the session ?
Posted on Sep 13, 2008
How to Share Files With Cerberus Ftp Server?
FTP and SSH SFTP are application protocols designed to allow
individuals and businesses to easily transfer files between
computers. The two protocols are commonly used to transfer
data reliably and efficiently, whether it is uploading important
files to your home backup system or securely sharing company
files between two remote offices.
Setting up an FTP server will allow you to receive and share files
with virtually anyone, anywhere in the world. This tutorial will
walk you through the basic steps of downloading, installing, and
configuring Cerberus FTP Server . In addition to standard FTP and
HTTP, Cerberus can also secure your connections with encrypted
SFTP , FTPS, or HTTPS .
You can also use this link to download it How to Setup File Server with Cerberus FTP Server
Oct 19, 2016 | Computers & Internet
Tip
Bullet Proof FTP Server Tutorial
This is for the BulletProof FTP Server 2.10. However, It should work fine on most following versions as well.
I'm assuming you have it installed and cracked.
Basics 1. Start the program. 2. Click on Setup > Main > General from the pull-down menu. 3. Enter your server name into the 'Server Name' box. Under Connection set the “Max number of users" to any number. This is the limit as to how many users can be on your sever at any time. 4. Click on the 'options' tab of that same panel (on the side) 5. Look at the bottom, under IP Options. Put a check in the box “Refuse Multiple Connections from the same IP”. This will prevent one person from blocking your FTP to others. 6. Also put a check in the 'Blocked Banned IP (instead of notifying client). VERY IMPORTANT! If somebody decides to 'Hammer' (attempt to login numerous times VERY quickly) your server/computer may CRASH if you don't enable this. 7. Click on the 'advanced' tab 8. At the bottom again look at the 'hammering area' 9. Enable 'anti-hammer' and 'do not reply to people hammering' Set it for the following: Block IP 120 min if 5 connections in 60 sec. You can set this at whatever you want to but that is pretty much a standard Click 'OK'
Adding Users 11. Setup > User accounts form pull-down. 12. Right click in the empty 'User Accounts' area on the right: choose 'Add' 13. Enter account name. (ie: logon name) 14. In the 'Access rights' box right click: choose ‘Add’. 15. Browse until you find the directory (folder) you want to share. In the right column you will see a bunch of checkboxes. Put a check in the following ones: Read, Write, Append, Make, List, and +Subdirs. Press 'select'. 16. Enter a password for your new FTP account. 17. Click on 'Miscellaneous' in the left column. Make sure 'Enable Account' is selected. Enable 'Max Number of Users' set it at a number other than zero. 1 for a personal account and more that one for a group account. Enable 'Max. no. of connects per IP' set it at 1
18. Under 'Files' enable 'show relative path' this is a security issue. A FTP client will now not be able to see the ENTIRE path of the FTP. It will only see the path from the main directory. Hide hidden flies as well. Put a tick in both of these.
Advanced: You don't need to do any of this stuff, but It will help tweak your server and help you maintain order on it. All of the following will be broken down into small little areas that will tell you how to do one thing at a time.
Changing the Port The default port is always 21, but you can change this. Many ISPs will routinely do a scan of its own users to find a ftp server, also when people scan for pubs they may scan your IP, thus finding your ftp server. If you do decide to change it many suggest that you make the port over 10,000. 1. Setup > Main > General 2. In the 'Connection' Area is a setting labeled 'Listen on Port Number:' 3. Make it any number you want. That will be your port number. 4. Click 'OK'
Making an 'Upload Only' or 'Download Only' ftp server. This is for the entire SERVER, not just a user. 1. Setup > Main > Advanced 2. In the advanced window you will have the following options: uploads and downloads, downloads only, and uploads only. By default upload and download will be checked. Change it to whatever you want. 3. Click 'OK’
While you are running your server, usually you will end up spending more time at your computer than you normally do. Don't be afraid to ban IP's. Remember, on your FTP you do as you want.
When you are online you must also select the open server button next to the on-line button which is the on-line Button
You also have to use the actual Numbered ip Address ie: 66.250.216.67
Or even Better yet, get a no-ip.com address
on Feb 08, 2010 | Computers & Internet
Tip
Create an FTP Server on your PC with Serv-u Requirement: Serv-u No-IP.com...
Requirement:
Serv-u
No-IP.com Website
Quote:
Step 1. Getting a static IP address. Get a static address for your FTP server. You will want to do this as opposed to using your IP address keeping up-to-date. Imagine having to change all of your setting every time your IP changed. With No-IP, the No-IP service runs in background on your computer and updates your current IP address with your FTP server's URL (for example, you get ftp://rkchoolie.serveftp.com). Second reason, you don't want your IP address posted out there for everyone to see.
1. Go to www.No-IP.com to create a new user account.
2. Fill in the information that is required and the click Register button.
3. Your account has now been created and your accound password has been emailed to you.
4. Check your email mailbox and wait for the mailbox and wait for the mail that contains your password
5. Go back to www.No-IP.com and type your email address and password to login to your account.
6. Once in your account, click on Add a host in the left menu
7. Type in the Hostname you want (example: rkchoolie) and pick a Domain from the list (example: ftpserve.com)
8. Check Allow Wildcards and click the Submit button
9. You now have your static address (example: rkchoolie.serveftp.com)
10. Click on your OS link in the Dyn-Update Client in the bottom right menu and follow links to download the client
11. Once downloaded, install the software and type in your email address and password when asked.
12. Finally tick the checkbox near your static address.
You now have a static web address .
Quote:
Step 2. Installing and setting the FTP server
1. Install Serv-U 4.0.
2. Start Serv-U and use the wizard to setup your ftp.
3. Click next until you're asked for an IP address, leave it blank and then click next.
4. Type the domain name you've just registered above (example: preacher.serveftp.com) in the domain name field and then click Next.
5. You are asked if you want to allow anonymous access, select No and then click next.
6. You are then asked to create a named account, check yes and then click next.
7. Type in the user name you wish for this account (example: Harrie) and click next.
8. Type a password for this account (example: $p3c1aL). For security reasons, try to create a password with some letters, numbers and special characters. Then click next.
9. You will then be asked for the Home directory of the account you just created. Select the directory and then click next.
10. Select yes to lock this account to the Home directory. You want to do this so that the user can not go any further up that his home directory. Click next.
11. The account is now set so click finish.
Quote:
Step 3. Configuring user accounts
1. In the left tree-menu, select the account you've just created and then click on the General tab.
2. Check Hide ‘Hidden’ Files.
3. Check Allow only and enter the number one in the box.
4. Set the Max. download speed to what ever you want. If this is an account that many will be using, set it low to save on your bandwidth. I usually have mine set between 10 – 20. If you leave it blank, users will be able to download from you at full bandwidth.
5. Set the Max no. of users to how many you want to be able to log on at one time. This depends on your connection speed but try these (56 - 1, ISDN - 3, ADSL or cable - 5-6 users.)
6. Now, click on the Dir Access tab.
7. You should see the home folder in there. Highlight it and make your permissions.
8. If you only want users to be able to download check only Read, List, & Inherit.
9. If you want users to be able to upload, but to only one particular folder but not download, click the add button and then select that folder. Now highlight the folder and set these permissions on that folder. Check Write, Append, List, Create, & Inherit. Once you have made the permissions click on the up arrow that is located at the bottom right-hand corner. You want this special upload folder to be list first, before the home folder.
10. If there is a folder that you don’t want anyone to have access to, but it is inside the home folder, then click the add button and then select that folder. Now highlight the folder and make sure that all checkboxes are left. Once you have made the permissions click on the up arrow that is located at the bottom right-hand corner. You want this no access folder to be listed at the very top.
11. There are many other different sets of permissions you can play with. I just covered your basics.
12. Your server is now set!
13. Try logging on with the username and password and see if it works.
on Jan 27, 2010 | Computers & Internet
I have tried to get my yahoo account connected to work with outlook to no avail
Do you pay for your yahoo mail? If you use the free version, you can't do it.
If you have Yahoo Mail Plus (19.95/yr) then go to the mail options.
  1. Go to Tools and Account Settings - below the E-mail tab click New
  2. Choose E-mail Service. Click on the Microsoft Exchange, POP3, IMAP, or HTTP radio button
  3. Click the manually configure server settings or additional server types check box. This will automatically enter in all of the required fields
  4. Click next
  5. Click on the Internet E-mail bubble. Click next
  6. Enter the following information:
    Your Name: Display Name you want to use, for example, Jo Bloggs
    Email address: Full email address, for example, jo.bloggs@yahoo.com
    Incoming Server: Contact your ISP or Hosting Company for this setting. (See note below if your mail provider is Yahoo!)
    Outgoing Mail server: Contact your ISP or Hosting Company for this setting. (See note below if your mail provider is Yahoo!)
    User name: The first portion of your email address, for example, jo.bloggs@domain.com
    Password: Your email account password
Note: If your mail provider is either yahoo.com, rocketmail.com, or ymail.com then the incoming and outgoing settings are as follows:
  • Incoming Mail Server pop.mail.yahoo.com
  • Outgoing Mail Server smtp.mail.yahoo.com
If your mail server requires SMTP Authentication, follow these steps. If you are not sure if your mail server requires SMTP Authentication, please contact your hosting company or ISP:
  1. Click on More Settings
  2. Navigate to the Outgoing Server tab
  3. Check My Outgoing Server requires SMTP Authentication
  4. Click OK
  5. Click on Next
  6. Click on Finish
Apr 24, 2011 | Computers & Internet
Cannot find wep
You may try :
Click on Start >> Run>> CMD >> type in IPCONFIG
Check the default gateway and put it into the address bar of Internet explorer.
Give the user id password >> Goto Wireless settings and check the WEP key
Otherwise :
Paste the link on the address bar of the Internet explorer or CLick on the link:
ftp://ftp.hp.com/pub/printers/ndu/
Click on HPHNDU_10...
Click on Save and save it to your desktop and run the software .
It will Show your Network Name and The WEP/WPA key .
Otherwise call the router company
Regards
Soumajit
Sep 20, 2009 | HP Computers & Internet
How do i publish my site? I have VodaHost as my hosting but I can't seem to get the two to connect
this is very simple, once u finish all works like domain registratin,web design...finaly u have to reach a hosting company to host ur site/publish ur site if u need any hosting assistance have a look at this http://www.tucktail.com/
Aug 26, 2009 | Cosmi Perfect Website Creator (ROM03919)...
Adding an IP address to Bizhub C353
at the copier press the scan button touch direct input tab,touch scan to smb, in the host name field enter the tcpip address of the target pc, in the destination folder enter the shared folder name, in the user id field enter the valid workgroup or domain user name, in the password field enter the user password, press start. at the computer you have to create a shared folder on the root of c: and give it all rights read and write allowed this is how to scan to a shared folder you can also sca to an internal email server or to a ftp server on your network or to a usb flash drive that you can plug directly into the machine
Jun 04, 2009 | Konica Minolta Office Equipment & Supplies
IPhone 3G and NetworkSolutions email configuration
Ok Here's what I did to resolve the problem...
This from network solutions plus the steps that i followed. The phone auto detected the ports settings. It automatically will atempt authenticate using ssl. once it failed it asked would i like to try not using ssl i selected yes. Note had to that twice. Then it worked like a champ
Good luck...
Dear Jon Smith
Thank you for contacting Network Solutions Customer Service Department. We are committed to creating the best Customer experience possible. One of the first ways we can demonstrate our commitment to this goal is to quickly and efficiently address your recent request.
Add email account on iPhone
  • If this is the first account you are setting up on iPhone, simply tap Mail and then select Other
  • If this is an additional account please go to the Home screen > Settings > Mail > Accounts > Add Account > Other
Enter account information
Select POP and then add the following information:
Name – The user’s Display Name
Address – The user’s full email address
Description – How you want to identify the specific email account, for example "work", or "home email"
Host Name -- mail.domainname.ext
Username – The user's email address
Password – The user's mailbox password
Complete the setup process - click SAVE and wait for the iPhone to test your incoming and outgoing mail settings and connect to your mailbox.
Please note: The iPhone should detect the Port Settings.
Incoming Setting
Use SSL: OFF
Authentication: Password
Delete from server: Never (you can set as you wish)
Server Port: 110
Outgoing Settings
Use SSL: OFF
Server Port: 587
We hope that this information has been helpful.
Please do not respond to this E-mail. If you have any additional questions, you can reach us via e-mail by completing our online form at http://www.networksolutions.com/en_US/help/service-request.jhtml or by phone at 1-866-391-4357 and provide Service Request # 1-xxxxxxxx.
Thank you for choosing Network Solutions.
Dec 11, 2008 | Apple iPhone 3G
How do we set up proper ftp server connection to receive scanned images with our Toshiba 232. the current file path is \\10.0.1.5/Scans\ but when we try to scan we get a FILE STORAGE ERROR. we have entered...
the path is all \'s not /'s. 10.0.1.5 needs a shared folder named scans and the copier needs a users valid login name / password for the computer sharing the scans\ directory.
Apr 01, 2008 | Toshiba Office Equipment & Supplies
Gprs settings
For BSNL South prepaid or post paid use following settings:
Start/ Settings/ Connections /GPRS
Connects to : Internet
Access point: gprssouth.cellone.in
Leave other items blank.
Start/ Settings/ Connections /Proxy
Donot creat any proxy
You donot require any thing else. GPRS will work on your mobile and also in Internet share. Internet share works with cable and bluetooth. Browse on mobile or laptop !!!
9448834529
Dec 10, 2007 | HTC Touch P3450 Smartphone
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
