Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Jandy one touch control screen
Had a lightning strike near our house and now the screen will not come on. The top of the screen has written " firmware Rev B11" .
any suggestions?
  • felixlcapria Sep 18, 2008
    My screen is lit and says firmware b12
    felix
Your RS board in the power center is shot. that message means there is no communication to the power center.
Posted on Nov 02, 2008
Panasonic plasma tv won't turn on standby light on and cooling fans on
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 14, 2015 | Panasonic Televison & Video
The house is over 40 yrs old were they all earthed
Yes, All House are Earthed since Benjamin Franklin first discovered how to save buildings from Lightening Strikes.
Read this:-
Lightning Rod
Rod believed to be an original of Franklin's
Once Franklin had an understanding of the behavior of electricity, he set about to protect houses from the destructive forces of lightning. A lightning rod, simply, is a rod attached to the top of a building, connected to the ground through a wire. The electric charge from lightning strikes the rod and the charge is conducted harmlessly into the ground. This protects houses from burning down and people from electrocution.
Franklin wrote, in 1753 It has pleased God in his goodness to mankind, at length to discover to them the means of securing their habitations and other buildings from mischief by thunder and lightning. The method is this: Provide a small iron rod (it may be made of the rod-iron used by the nailers) but of such a length, that one end being three or four feet in the moist ground, the other may be six or eight feet above the highest part of the building. To the upper end of the rod fasten about a foot of brass wire, the size of a common knitting-needle, sharpened to a fine point; the rod may be secured to the house by a few small staples. If the house or barn be long, there may be a rod and point at each end, and a middling wire along the ridge from one to the other. A house thus furnished will not be damaged by lightning, it being attracted by the points, and passing through the metal into the ground without hurting any thing. Vessels also, having a sharp point rod fix'd on the top of their masts, with a wire from the foot of the rod reaching down, round one of the shrouds, to the water, will not be hurt by lightning.
Look for 1/4" thick Copper Bare solid wire near where your Water pipe comes in the Hose or near the Electicty power comer into the house.
Mar 15, 2015 | Cars & Trucks
I have Jandy 8157 and one touch button unit in the house does not repond but the timers still works. I can control the unit from main pannel at the filter out side. Do i need a new mother board.
take the top front panel see if the red 4 pin connector is connected and tight if so check to see if the wire has been cut (sometimes by landscapers) if connected see if you have at least 10 volts or more at the plug if so check the red plug at the controller in house if not the same bad wire if 24 to 10 volts bad controller you can also try by system with jumper wire to see if it works
May 19, 2012 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Bosch dishwasher does not turn on following a lightning strike near the house last night
Check your circuit breaker first. If ok suspect control board got fried. If you take it out you may see a burnt spot on it.
Sep 25, 2011 | Bosch Dishwashers
Jandy aqualink says Firmware Rev B11?
my pool power is on but the remote in the house does not work.
firmware rev b-11 is showing on the display and the display lights up.
what could be the problem?
Apr 11, 2010 | Jandy Aqualink Rs4 One Touch Control...
Firmware screen
shorted wire to controller or plugs if all ok bad pcb board
Jun 12, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
864 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
