Question about HP Computers & Internet
How do I correct a blue screen stop.Shows on sreen xxxSTOP;0x0000008E(0xc000001d,0x80572dff,0xed5e4bc6,0x00000000) Tech info is C\DOCUM~1\skip\locals~1\Temp\wer7del,dir00\mimi091308,dmp C\DOCUM~\1SKIP\LOCALS~Temp\wer7del,diroo\sysdata.xml
  • skip stang Sep 14, 2008
    Yes Sir,
    Had a Dell A960 printer installed and workin fine for what it is,for about 5 months.Ran out of ink,and replaced with the same as per manufacturers instructions.Disconnected no cables at all.Went to make a copy and came up saying printer not installed.Made a copy without useing the lap top and worked just fine.So then i went to the correct driver in my system and attempted to launch it,then it came up on screen after i tried to print and the canceled that job because it would not print that the printer is running and would cancel after it was done.After waiting about a hour got mad and pulled the plug for power out the wall,as i could not shut down any other way.There is a battery on board but does not work,hold a charge or charges at all not sure why .Has not worked in a year or so ,dont think this whats wrong but then agian if i knew anything we would not be haveing this conversation.Just a note i am a full blown Dexlicsic so it does take me a little longer then most so im not saying i didnt do this all by myself,but i am the only one who uses this thing.
    Any help cant hurt,besides someone needs a pat on the back,the other fella helping me is great and he knew when i was getting overwhelmed!
    Thanks,
    Skip Stang
  • 68 Answers
This blue screen problem generally appears if you install an incompatible driver .. can you please specify is you installed anything after your system was working normally
Posted on Sep 13, 2008
0x0000008E (0xC0000005,0x805D946E,0xF78032FC,0x00000000)
Remove all USB attached devices like drives. You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode. To eliminate possible bad RAM. Unplug PC, open case, and remove all RAM. Test one DIMM at time, one slot at a time. Re-install Windows. Clean install works best, but all data will be lost. Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Dec 11, 2012 | Microsoft Windows XP Home Edition English...
I have a blue screen ,then when i restart it will be normal ,but after a while blue screen again : stop:0x0000008e(0xc0000005,0xBA5383c9,0xB8FE282C,0x000000) sysaudio.sys-Address BA5383c9 based at...
this is a general error and this might be because of the operating system that is somehow corrupted. another thing is memory (RAM) of your computer is malfunctioned.
try to run memory test. if the memory looks OK then back up your files and reformat your computer
Sep 07, 2011 | Evesham Evolution PC Desktop
Freezes after boot blue screen error 0x000000A0 and 0x0000008E
Hello,0x0000008E is usually caused by faulty RAM or misconfiguration of RAM. Have you done an memory upgrade recently?
Feb 23, 2011 | Gateway DX4640-UBC01A PC Desktop
Pc blue screens with 0x0000008e (0xc0000005, 0x807019uf, 0xaa7ff48c, 0x00000000) after reboot goes into safe mode boot option. Selecting xp pc boots normally. repeated reboots pc works fine. But if left...
STOP 0x0000008E errors are usually caused by memory hardware failures and more rarely by device driver issues, viruses, or hardware failures other than your RAM.
Download and run from a floppy or CD MEMTEST86 at
http://www.memtest86.com/
Aug 05, 2010 | Evesham Evolution PC Desktop
System is wont boot
Getting 0x0000008e is surely a signal that your registry is corrupted. What you need to do is to fix 0x0000008e as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don’t fix 0x0000008e, this potential risk will bring you more troubles, Even system crash.
Cause of the problem would be.Mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause 0x0000008e.
Heres how to fix the issue
Download the software fix by clicking here.
Launch it after finishing the installation.
Click “Scan Now” button
Click “Repair Problems” button and fix 0x0000008e.
May 21, 2010 | HP Pavilion dv6000z Notebook
Uploading windows vista upgrades command was to restart system for changes to take effect. On restart screen went blue and showed Tech info *** STOP: 0x0000C1F5 (0x00000000, 0x00000000, 0x000000000,...
Press F8 continuously while starting the computer. When black screen appears eventually (right before Windows loads), choose Last Known Good Configuration.
Aug 06, 2009 | HP Computers & Internet
Dell Dimension 4600 Blue Screen
Usually this blue screen appears due a hardware issue or drivers conflict.
1) Try to boot in safe mode (hit F8 after starting up) and select "Safe mode"
If you don't get access try doing this:
2) Run the OS CD and use the option Recover Console (R)
This will fix the problem.
3) If the problem continues, you will need to install the OS again.
Oct 07, 2008 | Computers & Internet
Blue sreen
check your connections if they are connected properly.have a tech check your tv the problem could be in the video section.good luck.
Apr 19, 2007 | RCA P52930BL 52" Rear Projection...
Computers & Internet Logo
192 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
