Lots of tiny bits of rubber flakes have comeoff door seal and are stiuck to washing
    Genius:
  • 1,239 Answers
Hi Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
Posted on Sep 13, 2008
How to remove remove rubber seal between door and drum
Hi,the door seal is held in place with a wire with spring on it,just open door get hold of rubber witch is attatched where door closes,
if you pull on the rubber at the edge you will see the wire you will have to get a flathead screwdriver to prise it out,once you take the metal band off just pull the rubber off,then if you pull on the rubber the inside bit of the rubber will come out.
hope this was some help.
Apr 05, 2015 | Zanussi Washing Machines
Rubber door seal small bit of rubber coming off.
strange one try e spares.com for a new one also check for inner drum move ment
Apr 03, 2015 | Samsung Washing Machines
How do I clean the rubber door seal
This video will show you how to change a door seal on this bosch
Jun 26, 2012 | Bosch Washing Machines
Problem: Forming on inside glass shelves: tiny beige sand-grain-like flakes. Why??
dear Cristina the color and the small flakes sounds like the insulation they use for the refrigerators ...perhaps somwhere on the door or sides of the refrigerator there is a crack or hole and the insulation just situates on the shelves inside other than that i never heard of anything like this. I hope this helps out
Dec 28, 2011 | KitchenAid Refrigerators
Model wm0642hw front load. it leaks by door frame.rubber seal with clamp.only 2 years old. do i need to change the door frame outer part a151? thanks for your response in advance
Hi, If the door isnt loose or broken? Its more likely to be the rubber door seal if its leaking between the seal and the door glass. Check the edge of the seal where it touches against the glass for damage or ware if its ok clean any soap residue or bits from the glass.If it still leaks change the door seal.
Regards Elect App
Jul 13, 2011 | LG WM-2277HW Front Load Washer
Door gasket has mildewed and need to remove it for cleaning.
This video will show you how to change a door seal on this Bosch front loader washing machine
May 14, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Getting what looks like mold on the front rubber seal/gasket
Front loaders do not dry out unless you leave the door open when not in use. Start leaving the door open and the mold will dry out and flake off. It will smell better also!
Mar 15, 2010 | GE WSXH208A Front Load Washer
BOSCH: How to replace rubber seal (boot) of front loading washer
remove soap draw take screw out lower right.
remove boottom panel screw in filter flap push to the right panel comes off undo 2 x screw,take front lip off door seal off 2 screw from door interlock then front panel will come off you will beable to whole seal and spring cilp
slightly longer but easy you can see what you are doing.
Jun 30, 2009 | Washing Machines
Black marks all over the rubber seal at the front of machine.
The mould you are referrng to is actually bacteria that is building up because you are doing too many low temp washes.
What you must do is a high temp wash periodically,with powder in but no washing.
Do this 3 or 4 times a year, more if you do a lot of wahing.
It is called a maintenance wash, and helps kill off the bacteria.
With a scouring pad or steel wool pad, clean as much scum as you can off the door seal. particularly in the folds of the seal.
You will probably be left with stains in the rubber, but as long as you have got the worst off, it should be o/k.
Please rate my solution.
Thanks.
Jan 21, 2009 | Hotpoint Aquarius WF000 Front Load Washer
GE front loader washer soap inside door
You can try using soap powders for 'front loading' machines......
Mar 03, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
110 people viewed this question
Top Washing Machines Experts
