Question about Kitchen Ranges
Mabe oven thermostat and stove flame adjustments
I have a new Mabe XO6500PX range and desperately need to know how to make adjustments. I'm in Venezuela and don't speak Spanish yet. There seems to be no such thing as simmer on the burners. Everything boils on the lowest flame. Is there a way to lower the flames? I also need to know how to adjust the oven thermostat. We're handy and can manage almost anything if we know how. There's nothing on the back of the knob. Just a long extension into the control. Thank you for anything you can do to help!
Sue at meerkat713@gmail.com
  • meerkat713 Sep 17, 2008
    Thanks, but there is are no screws behind the knob nor screw slots in the knob housing. That's why we're at a loss. I forgot to mention the oven thermometer read 325 when the oven was set at 400.
  • nbcamp May 11, 2010
    I have a Kenmore oven and its off by 25 degrees higher. How can I set the thermostate to be right on?
    Genius:
  • 1,239 Answers
Hi If the oven doesn't heat evenly or doesn't heat at all, the oven thermostat may be malfunctioning. First, determine how much the temperature in the oven is off from the control setting. To do this, put an oven thermometer on a center rack inside the oven and turn the oven on for about 20 minutes, with the thermostat set at any range between 300 degrees and 400 degrees Farenheit. If the oven thermometer reads 25 degrees or more lower or higher than the oven control setting, the thermostat should be recalibrated. Here's how to calibrate the thermostat:
Step 1: Pull off the thermostat knob on the control panel. Behind the knob are two screws holding a round, notched plate. Loosen these screws, but do not remove them.
Step 2: With a screwdriver, change the notch setting on the notched plate by turning the plate counterclockwise; for every eighth of a turn, the oven temperature goes up about 25 degrees Farenheit. To turn the heat down, turn the plate clockwise.
Some thermostats can be adjusted by turning a screw inside the control knob shaft housing. To do so, remove the knob and insert a screwdriver into the shaft so that the screwdriver blade engages a screw slot. Turn the screwdriver counterclockwise about one-eighth of a turn to raise the heat about
25 degrees Farenheit. Here's how to test a malfunctioning thermostat:
Step 1: Test the thermostat with a VOM (multimeter) set to the RX1 scale. The thermostat is located directly on the back of the control knob that regulates the heat. To gain access to the thermostat, remove the back service panel to the control panel.
Step 2: Disconnect one electrical lead wire from a terminal of the thermostat and clip one probe of the VOM to each thermostat terminal. If the thermostat is in working order, the meter will register zero. If the needle jumps to a higher reading, the thermostat is faulty and should be replaced.
Step 3: If necessary, replace the thermostat with a new one of the same type.
If you need to replace the thermostat, follow these guidlines:
Step 1: Disconnect the terminal wires to the thermostat and pull off the control knob.
Step 2: Remove the retaining screws. On some ranges, there is a wire running from the thermostat into the oven. This wire operates a sensing bulb that controls the thermostat. The sensing bulb is usually held by a bracket; unscrew this bracket to remove the bulb. Then carefully slip out the wire, the bulb, and the thermostat.
Step 3: To check an operating thermostat, first make absolutely certain that the power to the dryer has been turned off and the dryer is cool. Then disconnect the leads to one side of the thermostat. Test an operating thermostat with a VOM set to the RX1 scale; clip one probe to each terminal of the thermostat. Disconnect the leads to one side of the thermostat so that the meter won't give a false reading. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
Posted on Sep 13, 2008
How many spanish speaking countries or there ?
Spanish Speaking Countries (official)
NOTE: Spanish is spoken in many countries, but it is an official language in the following countries.
1. Argentina
2. Bolivia
3. Chile
4. Colombia
5. Costa Rica
6. Cuba
7. Dominican Republic
8. Ecuador
9. El Salvador
10. Equatorial Guinea 11. Guatemala
12. Honduras
13. Mexico
14. Nicaragua
15. Panama
16. Paraguay
17. Peru
18. Spain
19. Uruguay
20. Venezuela
Jun 25, 2014 | Computers & Internet
Pin blocked don't have puk code sorry don't speak english
Which language do you speak I speak german and spanish maybe i can help you.
If the pin its blocked you should try to go to the company that provides the service.
Aug 28, 2011 | LG GW300 Cell Phone
New Garmen is in Spanish. Want to change to English. Purchased in Ontario, Ca. at Costco.
  • Press TOOLS (The spanner icon at the bottom right of the screen which shows WHERE TO and VIEW MAP
  • Press SETTINGS (The spanner icon) or LOCALE (The blue icon) on models that don't have a settings icon
  • Press LANGUAGE (The lips icon)
  • This brings you to a screen with 3 items; VOICE, TEXT LANGUAGE and KEYBOARD
  • Press TEXT and change it to AMERICAN ENGLISH
  • Press VOICE and select a voice from an English speaking country
If you don't speak Spanish there may be a bit of trial and error involved but I hope I have given you enough information to solve your problem.
May 22, 2011 | GPS
MABE Stove Manual in English Model : EM6120B2
hello i recently bought a mabe 6 burner gas stove but i need to know the manual is not in english and do i have to plug in before i can turn the gas on? its electronic ignition by the way
thanks
customer
May 19, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
THE fan is defective
i dont speak spanish but take the fan down. when the switch is off... unhook it and bring it to any home depot with the recipt you will get a new one
Aug 26, 2009 | Hampton Bay 52 In. Black Huntington III...
Not receiver signal
Maybe you need a digital converter for your t.v. Most car t.v's only pick up ntsc,pal. The new digital is atsc.
Jun 14, 2009 | Car Audio & Video
Mabe gas range
I HAD JUST PURCHASE A MABE 30' GAS FREE STANDING RANGE AT A LOCAL STORE HERE,THE BURNERS WERE ABSENT BUT I WAS ABLE TO SOURCE THEM AT THE MAIN BRANCH,I AM ALL THE WAY IN JAMAICA.I HOPE YOU CAN SOURCE IT,IF NOT FEEL FREE TO LINK ME UP AT fidel_perry28@hotmail.com,i will pass on the relevant info.good luck.
FIDEL
Jul 24, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Spanish to english
machine is speaking Spanish, need back to English.
hotrock, AZ
Feb 08, 2008 | GE 29875GE Digital Answering Machine
Kitchen Ranges Logo
3,429 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
