Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
Red, bule, green lines do not line up together.
Up until a few days ago the screen was gorgeous. Now we see green lines especially, but can also see red and blue when there is print on the screen. The actual model number is 55PP93 5217 Chasis number is DPTV310
  • 1 more comment
  • Anonymous Feb 14, 2008
    Same thing here.... one day perfect, the next day - green halos around words and the color are off.
  • Anonymous Feb 20, 2008
    THE COLORS ON THE SCREEN ARE ALL MESSED UP WE NEED TO GET THEM FIXED. LOAT OF GRENN AROUND THE PEOPLE.
    WHERE CAN WE GET A MANUAL?
  • blkteddibear Nov 23, 2008
    please help i have the same problem, but i have tried the manual convergence and the lines are not straight so when they meet they look loke they are looped one end meeting and the other not.....please help
  • Philips Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your Red, bule, green lines do not line up together. - 2c07611.png chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from
www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 15, 2009
    President:
  • 3,130 Answers
Your gonna have to trouble shoot the convergence PC board. if you know solid state electronics you can buy the service manual at sams photo facts and Then go from there. most of the time its a couple of LSIC's Sometimes its also a problem with cold solder connections on said IC's on the convergence PCB. If your not a tech but a handy man I would advise you to get a tech to troublke shoot this problem as if you pull the wrong plug or touch the wrong thing ,Not only can you cause serious problems to your investment ,you could also seriously be killed!! Call A pro Please. Good Luck
Posted on May 22, 2006
I lobe you my darling you lobe you my hard
Posted on Dec 12, 2008
This is a common problem with rear projections especially this model. Most of the time this happens when you recently moved the tv or had a hard bump on it. The non-tech fix which I advise you to try first is to go into your tv's menu and go under the picture settings and go to manual convergence. From there you can go to the separate colors and manually adjust them with your remote. All you have to do it go to each little cross-hair and move them until you don't see two definitive lines anymore. Once you have all of them lined up again don't forget to save your settings on the menu before exiting. You should notice a difference immediately if they were significantly off. If not then it might be time to call a prof.
Posted on Apr 30, 2008
Colourd line on the screen
it may be the flex cable that connects the lcd to motherboard
Aug 20, 2009 | Computers & Internet
Vertical red lines on screen
try a dif game and send me a msg at kickop1@ymail.com
Jun 27, 2009 | Microsoft Xbox 360 Console
Red screen and lines, then TV shuts off automatically
Adjust RED screen drive down, or disconnect,unplug CRT board from red tube turn set back on if it plays without shuting off RED tube is shorted or video IC on CRT board is bad.
Jun 19, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Some black colors are replaced with red blue flickreing in whites
Hi there
Firstly reinstall the graphics drivers, if its still the same there is a problem with the graphics card and you'll have to have it looked at.
Good luck and thanks for using Fixya!
Feb 06, 2009 | Fujitsu LifeBook C2340 Notebook
Adjustments on the RED, Green and Blue
you ahve to line the red and bule up with the green since the green is imobile
Oct 10, 2008 | Sony KP-51WS500 51" Rear Projection...
why is my projection tv screwed up on the left side with the color red only i tried to center it and it won't go any further.
Sep 05, 2008 | Televison & Video
Having the same kind of problem, only mine occurs twenty or so minutes after start up and only on the left and right sides of the screen.
Jan 20, 2008 | Samsung HC-P4752W 47" Rear Projection...
Red Green Blue Across The Screen
Yes, especially big screen. It sounds like convergence is out of lign. Try menu and straighten out, wait until set is warm first.
Dec 06, 2007 | Sony KP-46WT520 46" Rear Projection...
I have 47 inch with double color in picture, reds and green
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergence amp ic bad
Oct 14, 2007 | Samsung HCL552W 55" Rear Projection...
Red Vertical Line and Black Screen, Sound OK
Check this out
http://forum.eserviceinfo.com/viewtopic.php?t=30810
have a nice day
Oct 08, 2007 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
4,594 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
