Question about Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range
Smeg A2 - Oven gets too hot
Hi
I had just to replace the fac element, on using the oven for the first time the inner glass of the main oven shattered. I have now replaced the glass and have tested the oven to about 100C using a oven thermometer, however the oven got to 100C and the red light went out but the temperature inside the oven went up to about 150C within a few minutes so I turned it off and opened the door to allow it cool down before more breakages!
I've doubled check with Smeg Services UK that they have supplied the correct element and they assure me they have. What is wrong now !!
    Sergeant:
  • 409 Answers
Is there a heat probe inside the oven? sound like you owen is overheating. i would check the TOD, if the oven has one. this thermostat regulates the temperature and if it's "open" it needs to be replaced.
Posted on Sep 13, 2008
SMEG SPA 42016, tripping switch after oven on for certain time, is this thermostat or Element issue?
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 13, 2013 | Smeg Ovens
Hi smeg se210x/1 doesnt want to heat up to a decent temperature?
May 30, 2011 | Smeg SE210X/1 Stainless Steel Electric...
The main oven inner glass door panel has shattered
Unfortunatey, it happens quite frequently, there is no one reason for it to do so.
The only solution is to replace it.
Over a number of years use, the glass looses it's properties, and this is what can happen.
Jan 24, 2010 | Zanussi Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
I have a smeg self cleaning oven on the first occasion I used it when it was just out of warranty to glass shattered and I had to pay eighty euros for a replacement. Last Tuesday I used the self cleaning...
do not use abrasive cleansers on the glass,fine scratches will cause failure in high temperatures. do not use Philip again untill you call around for the best price.!
Sep 23, 2009 | Smeg DO81CSS Electric Double Oven
Fan working,grill gets hot but the oven doesn't
NEEDS NEW FAN HEATING ELEMENT.
ORIGINAL WENT ON MY A2 AND I REPLACED WITH A STRONGER
3 ELEMENT INSTEAD OF THE 2 ELEMENT ORIGINAL.
IT'S BEEN FINE SINCE.
May 11, 2009 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven not working
You have a element and or a faulty thermostat
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Glass breaking
go to a supermarket a buy a thermometer that is oven safe.put the thermometer in the oven and set it to 350 degrees.when the oven light goes out open the door and see what the temp reads on the themometer.it could me the tstat,are you getting the correct voltage to the element or not sure?
Aug 13, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smeg main oven failure
Apr 01, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smeg A2.5 Dual Fuel (Electric and Gas) Kitchen Range Logo
824 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
