Question about LG Electronic Window Air Conditioner
My air conditioner
My air conditoner was not draining at all,and my husband had to take the cover off,there was a nasty slimy pink substance inside of it and it had it completely clogged up.If anyone can tell me how I can keep this from happening again please.
  • 958 Answers
Angela,
the slimy pink substance is the product of long usage and is a normal accumulation of dust and dirt.
have a regular cleaning of the unit to prevent another occurrence of the water not draining out. usually every three months depending on the location of the unit.
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
How to remove face cover for cleaning
The front covers are usually snapped into place. Grab at top and bottom and pull. It should pop right off. GOOD LUCK FRIEND.
Sep 15, 2014 | Whirlpool ACC184PS Thru-Wall/Window Air...
My window air conditoner is leaking water inside and what can I do to prevent that?
Make sure the unit is tilted down at the rear at least 1/4" to 1/2" and that the drain hole in the drain pan, under the rear of the unit is not clogged. The drain hole can be hard to find, as clogs blend in with hole. So, be persistent in looking for it.
Hope this helped you Elaine. Thanks for choosing FixYa.
Jul 23, 2011 | GE AJCQ08ACB Air Conditioner
I have a sharp portable air conditioner . The coils are dirty and have a pink wet looking gel substance on them. I cannot remove the front. So what is the best way to clean them?
That pink substance is mold. you can use a non rinse evaporator coil cleaner its simple and quick. just sparay it on a run the a/c.
Jun 28, 2011 | Heating & Cooling
Why is the fabric conditioner not draining from the draw?
Bosch Washing Machines fabric conditioner not draining from the draw, This video will show you how to keep your
soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Jun 21, 2011 | Bosch Washing Machines
I have an unseen leak soaking front passenger floor. When I took up the carpet the insulation under it was completely saturated.
Either your heater core is leaking, is the fluid sweet smelling and slimy? Or the condensation drain from your air conditioner is plugged causing the condensation to drain inside as opposed to outside. Or the glass seal is bad and rain water is coming inside from around the windshield. Heater core is going to need a repair guy, condensation drain can usually be fixed in about 5 minutes at any shop with a lift, glass leak you are going to need an auto glass shop's help.
Aug 25, 2010 | 2004 Dodge Stratus
We have a leakage of water when the unit is run.
remove the cover and in the right hand corner is where the drain trap is usually located the can become plugged with a scummy like substance from the condensation or if you go to wherever the end of the drain from the unit is located you can actually blow through the drain an d remove most plugs
May 29, 2010 | Sanyo 18KS52 Air Conditioner
Air conditioner leaking in cold air in the winter
usually a cover goes on the outside but TOO HIGH your super needs a boot in the ****.open the front grill and put a towel or hand towel over it close cover back.that should help till your super gets a ladder
Nov 13, 2008 | GE Built-In Room Air Heat Cool Air...
Water is only trickling through
well my air conditioner was not draining at all and my husband took it out of the window and took the cover off,there was some sort of thick sliming nasty stuff in it that was causing it to be clogged up.It just a suggestion you can check it.
Aug 03, 2008 | Heating & Cooling
Delonghi Pinguino Classic Portable Air Conditoner Works for 30 min then red light comes on
Have it serviced. It cost me $250 to have a pro do it. Also, check the timer (the dial is hidden by a sliding cover on my unit). My husband cleaned it himself a year later and he took it apart to do it and it works much better now. When he opened it up, it was full of calcium deposit and dust. He told me he did not think the unit had been cleaned properly by the pro.
Jun 19, 2008 | DeLonghi PAC85 Portable Air Conditioner
Coleman Mach roof top ac
Under the drain pan on each side should be a small plastic drain plug they might be clogged up with debris.
Jun 07, 2008 | Dometic Rooftop RV Air Conditioner
LG Electronic Window Air Conditioner Logo
116 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
