Broken plastic gear tooth - Fellowes P55-C Shredder
I have a P55c Fellowes Shredder, the engine runs but it wont shred because the teeth have sheared from one of the intenal plastic drive wheeels - the wheel is a combined large and small drive wheel.
Is there a web site or phone number to order parts in the UK ?
Thanks for your help.
  • mlesueur Apr 08, 2009
    No gear teeth for my Fellows P55C.  No spares in UK
  • Anonymous Mar 26, 2014
    p55c
I suggest using Belzona (metal compound). Mix it with its hardner, paste it over the broken gear (dont worry if it gets over a couple of other gears. Let Belzona sink and dry (4-5hours). Get a Dremel drill with a fine blade on it and cut accurately where the teeth are meant to be. Voila, you have fixed your gear.
Posted on Oct 24, 2008
i had the same problem on the fellowes fs5m model. i opened up the machine and found that the plastic gear was completely worn on one side.
i just found this website online for spare parts: http://www.wheelermachines.com/fellowes_parts.htm
haven't called them yet. if they don't have it i might try the belzona compound.
good luck,
marie
Posted on Nov 02, 2008
Plastic stuck in my Fellowes shredder blades!
Sorry, but no. There isn't really a way, unless you are very technically minded, to take the teeth apart and clean them. You might try, using a paperclip, I find that I have to do that on occasion to clear out the pieces that get caught in between the teeth.
or maybe, just a thought,?... You can use a product called goof off, it does come in a aerosol can as well, in addition to small bottles of the product in liquid form. Good luck.
Mar 31, 2015 | Fellowes Powershred PS-65C Shredder
Broken cog spool - replacement
Hi you should buy new shredder because you will not get the plastic part easily and usually they do not be replace.
Jul 28, 2010 | Fellowes P57Cs Shredder
One of the gears in my sb-97cs has broken. The motor runs but the broken gear prevents the teeth from rotating and pulling paper into shred. I have spoken with people at Fellowes on the phone and they have...
I have the same problem with a stripped gear, to remove the top i found it best to place the shredder on its back, then with a pozi screw driver there are 5 screws securing the top in place, these are inside the shredder above the paper bin, 1 in each corner and 1 in the centre.
Hope this helps.
Jan 14, 2010 | Fellowes Manufacturing Powershred SB-97CS...
Shredder starts to shred, then makes a loud noise, and blades don't turn
sounds like a couple of teeth on a drive gear may be broken. call Fellows at1-800-955-0959.
Dec 01, 2009 | Fellowes DM15C Shredder
My Fellowes ps-40 will not shred. The motor is
you have some shredded gears. i don't think fellows has replacement parts for their personal shredder line.
Nov 15, 2009 | Fellowes 3011001 Shredder
Broken plastic teeth
I suggest you just go buy a new shredder, otherwise, if you really want to fix it. That would cost you more then you go buy a new shredder.
May 03, 2009 | Fellowes 3011001 Shredder
I need the large main drive gear for the Fellowes PS60C-2
200$ shredder or a 6$ replacment gear ,,,, great advice
takes about 10 min to replace the gear too
Apr 05, 2009 | Fellowes PS60C-2 Shredder
Makes a buzzing noise and won't shred. This is a Royal 140 cross cut shredder.
There is something causing the motor to not run properly. My guess is that the shredder gear (one of them) has a tooth stripped. If it is under warranty, call Royal. If not, carefully open up the unit to inspect (unplug it of course). I had a Fellowes PS400 unit and the plastic gear had a tooth broken on it. Fellowes was never able to solve the problem so I trashed it
Mar 08, 2008 | Computers & Internet
Fellowes P600C-2 Motor runs in reverse, but not forward
On mine a tooth broke from a drive gear. I am trying to find somewhere where I can replace this part.
Oct 25, 2007 | Fellowes P600C-2 Shredder
Shear pin ??
You most likely have several teeth broken off the drive gear that drives the cutting block. Not too difficult to replace but you need some special tools. A deep well socket (I think it's about a 3/8") to remove the cutting block and replace the broken gear. The gear should be available from a Fellowes dealer, or they might sell it to you direct if there is no dealer near you.
Let me know if this helps.
Aloha,
Bill Monroe
Oct 15, 2007 | Fellowes 220C-2 Shredder
2,061 people viewed this question
k24674
jasbo
jasbo
