Question about Goodman Heating & Cooling
My goodman cple18-1c model central AC unit blowing hot air
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Ths sounds like the outside unit or compressor is not kicking in, check for power to the unit at the breaker box, or at the bottom of the contacts!
Posted on Sep 13, 2008
What is wrong with my Goodman AC unit?
Sounds like it has no power getting to it at all. Dont forget that some circuit breakers have UP as ON and some have DOWN as ON. Do not just assume a common way is always the same. You may even have to have one UP and the other DOWN as on. Check what the switch or circuit breaker has written on it to be sure.
AIR CONDITIONERS run like a refrigerator, they manufacture their own Heat or Cool and blow air past the unit to give hot or cold air to cool or heat the Room. These do not require flowing water.
Sometimes people (wrongly) call EVAPORATIVE COOLERS air conditioners. (An evaporative cooler just blows AIR past flowing water to humidify the flowing air and therefore "cool" the area)
An evaporative cooler therefore would require running water and without flowing water, the unit may not start due to the installation of a "fail safe" switch. An evaporative cooler would generally have a large box mounted on your roof with open sides with filters which are kept moist by the running water and through which the fresh air is sucked and pumped into your home.
There are varying thoughts on both, I personally consider the REFRIGERATED style as the most effective type, but they are more expensive to install and run.
May 29, 2014 | Goodman Manufacturing GSZ130181A - 1.5 Ton...
How do I get my heater to blow hot air?
I assume this is gas . induced draft blower or ignitor.
Apr 30, 2014 | Goodman GMS90703BXA Heater
Central heat not blow hot air
you posted in november if it was very cold auxillary heat issue.
Nov 11, 2013 | Goodman Heating & Cooling
Goodman model aruf486016AA is not blowing hot air
Need more info. Does blower come on when calling for heat?
Nov 11, 2013 | Goodman Manufacturing Goodman ARUF486016...
My central air unit comes on but it's not cool and
to me it sounds like filter are dirty, need to be cleaned or replaced, home systems, packaged or otherwise are hermetically sealed and should not need freon recharge. Always start with airflow and/or unit being set too low. An AC unit of any type will build ice if a) the filter is plugged up and can't move enough air, b) it has been run without the filter, clogging the coil, again, not moving enough air, c) setting an AC unit below 68 degrees F will almost ALWAYS cause icing, and d) running a standard AC when it's warm inside and cold outside (unless equipped for "low-ambient operation"). When in doubt, a bit of maintenance(thorough cleaning) by someone with AC skills can cure a b, common sense will cure c d.
Reply
Jun 23, 2011 | Goodman CKL42AR42 Air Conditioner
Why would cool air be blowing out of my central ac unit condensor that sits outside? The other unit I have next to it blows out warm air and responds well to thermostat changes. The unit blowing cool air...
It probably has a low refrigerant charge. The air coming out of the outside unit should be warmer than the outdoor temperature when in the cooling mode and if it's a heat pump it should be colder than the outdoor temperature in the the heating mode. Check the big line going to the unit, it should be somewhere around the 40 F range and the small line should be hot.
May 23, 2010 | Goodman CKL24AR24 Air Conditioner
My heat unit will not blow hot air unless we go outside and hit a button on the back bottom of the unit. Once we do that it will blow hot air for that cycle. when it is time for it to come on it is cold...
If it does not have a furnace or heating elements for heating, then it is a heat pump, which is rare for a central AC system, but makes sense of the fact that it blows warm air when you reset the pressure switch, which may indicates freon pressure charge problem if your AC system has a reverse valve and uses freon to for heating (heat Pump).
Do you get heating when outside unit runs? if you do, check freon pressure levels and top up to required pressures. The button you depress is a pressure reset switch ... that is if your AC system is a heat pump ... which, as pointed above, it is not common for central ACs.
Nov 07, 2009 | Ruud Central System Air Conditioner
Goodman CK30-1A Central AC Unit will not run by thermostat
double check your t-stat wiring your not getting 24volts to the contact at the cond. unit outside
Jun 20, 2009 | Heating & Cooling
Goodman Furnace/AC unit not working 3a fuse blows even after replacement. once thermostat is turned on and clicks to start ac unit the fuse blows
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Jul 03, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
369 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
