Question about Kitchen Ranges
How to change a burne on gas stove - Kitchen Ranges
    Sergeant:
  • 409 Answers
Which part of the burner are you changing? can you supply the model # off the stove?
Posted on Sep 13, 2008
There is black soot all thru my oven and surrounding cupboards in my kitchen.I do not use the self cleaning feature,is this normal for this type of stove?
This is NOT good. Soot comes from something burning, and that's definitely not good. Do you smell smoke or something burning? Is the stove electric or gas? I would have someone pull the stove away from the wall and check to see what is burning. It could be wires, but something is very wrong. Please don't use the stove until you have it checked out, you could start a fire. Really, please have this checked out ASAP!
Apr 10, 2015 | Kitchen Ranges
Gas stov not lightup
it is in the gas line to your burner, you need to call a technician. do not play with it, as you can create a gas bubble and burn yourself.
Mar 01, 2015 | Stoves 600SiDOm Gas Kitchen Range
What is a liquid gas stove?
A liquid gas stove is a type of stove that uses a fuel tank in order to operate. Liquid gas stoves are capable of burning different types of fuels like alcohol, white gas, automobile gas, and kerosene.
Oct 25, 2012 | Camping, Backpacking & Hiking
Just recently our 10 year old stove started smelling funny only when its on. the burner burns but the flame is yellow and was normally blue. I understand the air fuel mixture could be off, how Do I fix...
Gas flame on all gas appliance should burn clear blue.
Yellow flame means you need to clean the burners.
This applies to stoves, oven, furnaces, water heaters
I did a google search for: clean burners on gas stove.
There was more information and helpful tips on those links than I can honestly repeat here, including how-to videos.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on appliance.
Jan 03, 2011 | Hardware & Accessories
Heater turns on and off randomly. Mostly the heater stays on for only 5 to 10 minutes. Had the thermostat changed 5 times by reputable heater man who also installed the wall cozy unit 4 years ago. One...
hi there
could have a faulty gas valve which may let in to much gas.extra load from the stove may be correcting this.
to much gas /too rich a mixture can affect internal temperatures causing thermostats to fail.
does the stove burn a nice strong bright blue flame?.
hope this helps the mystery
Dec 19, 2010 | Cozy (W352E) Heater
The gas stove fire burns with black soot and is only 1 month old
Gas should not burn with soot, if it does it is dangerous as poisonus fumes will be produced as the air/fuel mix is wrong.
Call a qualified gas engineer to check out the installation and make it safe.
Nov 11, 2010 | Microwave Ovens
Burned out Napolean stove.
Hi i would write to the company first asking about this problem see what they come back with bypass the rep go higher
Feb 12, 2010 | Napoleon 36" Zero Clearance Top/Rear Vent...
GE range stove #317B6641P001
Hi thanks for the question. the problem you are having is with the igniter. it does not get hot enough to work at 100 % . replace the igniter. thanks te appliance doc
Sep 10, 2008 | GE Profile JGSP44 Dual Fuel (Electric and...
My propane camping stove is burning with alot of soot.there seems to be an oily discharge in the line when i disconnect.the line runs directly to a 20 lb bottle bypassing the regulator as it is a high...
soot is incorrect gas / air mixture--too much gas
I am thinking that it is designed to run with screw on bottles ( low pressure ) yet you have connected it direct to a 20 lb bottle with out a regulator and have got adaptors to enable that
Not only do the regulators act as blow back extinguishers ( preventing a cannister explosion ) they control the gas pressure to obtain the correct air /gas mixture
try attaching a regulator to the top of the bottle , them a hose to the camping stove and your problems will be solved
Dec 02, 2017 | Sport & Outdoor - Others
GE Profile Spectra Kitchen Range
Are you using natural gas or propane (LP)? It sounds like you may need to change the orifice size on the gas lines going to each burner. If you are using LP and have the orifice set for Natural gas, the flames will burn higher and hotter, causing heavy soot. Under each burner, there should be a small nut with a hole in the center at the end of the gas line. The hole for Natural gas has a slightly larger diameter than one for LP. Your stove should have come with extra orifices as part of a conversion kit. Could this be the case? There's also another orifice in the main gas regulator in the back of the stove. Have you checked to see if the orifice for the regulator is set correctly? Does the oven burn hotter than usual with heavy soot, too? If you could please answer these questions first, I can give you better advice. Let me know...
Aug 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
49 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
