Question about iRiver iHP-140 MP3 Player
Repair I spilt some contact lens solution over my iriver and it has gone crazy! When I turn it on it automatically puts the volume to maximum and I can't control it. The selection highlighter moves up and down the options continuously and then I am unable to turn it off. I have tried resetting it several times but nothing seems to be working, except letting the battery run down. I have had it for nearly two years and was wondering where I could get it repaired?
    Problem Solver:
  • 6 Answers
Avsense at 4038clipper ct in freemont ca 94538 there info is on the iriver website they are very good and fix them pretty fast i just had mine there and am very happy with there work!!!!
Posted on Nov 03, 2007
    President:
  • 3,130 Answers
Its probably not worth repair as damage has already been done. You should have the owners or operators manual and that should have if case of trouble section to guide ya to the right place for repair. Now if you want get a full can of a spray called tuno wash with no lubercant in it. First off make sure its not gonna harm the palstic case by spraying a little on the back cover and let it stay there to see if any mis shapeing or melting occurs. Next if you can take off the back of the player and with the batteries out start spraying out the unit till you think you have saturateded the whole unit. Put it aside for an hour or so shaking out any excess liquid. Now put back the batteries and see what happens??? If it cleaned out the corrosion then good . If it didnt change anything or dosent work at all then your no worse off. Really when you first know that you spilt anything no matter how much water or liquid inside anything electronic, right away take out the batteries or unplug unit, and let it dry out of a day or so. Good Luck
Posted on May 21, 2006
How do I reset the volume on my tv?
your controlles on the tv set itself goes faulty simply spray some switch cleaner in buttons should sort you out
Sep 15, 2014 | Toshiba 40RV525U 40 in. LCD TV
I have an ITP180B that the maximum volume has suddenly gone down. The volume we used to get at 25 on the scale is now barely there at 40 on the scale
Is the sound distorted? For more information, or to inquire about a repair, please visit my website at audioserviceclinic.com. You may contact me directly though the website. Thank you.
Dec 17, 2013 | iLive ITP180B Speaker Bar with Dock for...
Volume Control Problems
if the volume control is a rotary dial. The dial itself has gone bad or is worn out.  I'd most likely replace the unit as repair will be about the same price or more.  Buy an mp3 player instead.
Mar 29, 2009 | Durabrand Anti-Skip CD-915 Personal CD...
Iriver h10 20 gb
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Then firmware upgrade
May 25, 2008 | iRiver H10 MP3 Player
I need to restore the system files for my H10 Iriver MP3 player
go to www.iriver.com people - what the f--- do you think it means?
May 04, 2008 | iRiver H10 MP3 Player
IFP-380T MP3 Player Problem (doesn't turn it on)
Here's my shortcut:
Here is a suggestion from the iRiver website - you may want to visit that website, b/c their "Ask Alice" tech support feature is actually quite good:
The players come with a CD that contains drivers and software that enable the player to download data from a PC. Insert the CD in the computer's CD drive, and connect the player to the PC with the USB cable. (Help with USB cable connections) The PC should automatically detect the device. The New Hardware Installation Wizard will automatically launch and the installation process will start.
If the above procedure does not occur on your PC, please manually install the driver. Use the links below for instructions:
If you still have trouble, the issue may be with the computer chipset. iriver has tested many PCs and discovered that this only occurs in a small number of main boards.
Apr 19, 2008 | iRiver iFP-380T MP3 Player
Screen Troubles
Sounds like the LCD controller has gone bad - must be replaced.
Try every "soft fix" first to be sure:
*Reset - button on side
*Firmware Upgrade (sounds like you tried it)
*Reformat the player -p.68 of manual - available on iRiver website if lost - enter model as H300 series
*Recovery -
-Tha Mp3 Doctor
Jan 11, 2008 | iRiver H340 MP3 Player
Iriver T20 USB went DEAD
Try this: disconnect the player from the computer, turn it off Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
All the info/manuals/drivers/upgrades for the iRiver T20 can be found here:
http://www.iriver.com/product/p_detail.asp?pidx=71
Aug 15, 2007 | iRiver T20 MP3 Player
T20 makes me mad
Apr 05, 2007 | iRiver T20 MP3 Player
iRiver iHP-140 MP3 Player Logo
59 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
