Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Sluggish Starter I have an 83 stroker. My starter is starting to get sluggish and pulling tons of amps. when off bike starter spins quick and well. reduction gear is slightly worn but not a problem. on the bike it's r..r..r know what I mean? Thanks
  • 216 Answers
The first thing that comes to mind is your battery. Are u sure its good ? Takes less amps to spin a starter than turn the motor. If you havent, I'd charge it up and try and turn the motor over a couple a times and then check the charge, or swap it out with another battery you know is good and see if you have the same problem
Posted on Sep 14, 2008
Starter sluggish the battery and alternator work fine 2004 Aztec and there are no loose wires yet it hesitates one time and then the next its fine
Do a voltage drop test on starter , cables ! Check the starter relay ,PCM energizes the starter relay . Check power an the control circuit of starter relay . Videos on you tube on doing these checks . Starter Voltage Drop VEHICLE RELAYS Testing from the relay base
Jul 16, 2016 | 2004 Pontiac Aztek
What's your problem?SLUGGISH STARTER
one of a couple of things ,bad earth connection from engine to chassis ,starter motor windings faulty or a cell down in the battery .
Apr 07, 2012 | Cars & Trucks
We have a 2002 Grand Cherokee that we have just bought. Dealer installed a brand new battery because of sluggish starts. In a week the battery is acting weak again, sometimes it starts fine, other times...
I was having the same issue with my 95 GMC. I replaced the battery and alternator. It would start fine at times, at other times it would be sluggish. I finally took the starter off and had it checked. Turns out the starter was bad. When it would get hot, it would act as though the battery was dead. Replaced the starter and it has not acted up again. Have the starter checked. Replace if bad.
Jul 01, 2011 | 2002 Jeep Grand Cherokee
GSF1250 Bandit - intermitant start. Starter motor will some times crank over and engine will start immediately. Other times the starter motor will not even click. Battery fully charged. Side stand up...
there is a common fault with the 1250 bandit in that the magnets detatch inside the starter motor and it eventually breaks up and stops working, this can begin with sluggish starter especially when hot, it would appear to be a flat battery but the power required by the failing starter can drop the battery off quickly to confuse you when trying to find your fault
Jun 12, 2011 | 2007 Suzuki GSF 1250 Bandit
Sluggish on start up i have changed the plugs, filters, oil, oil filter still dont understand the problem thanks from ed
How old are the O2 Sensors ? More than 100,000 miles !
Have you Checked and TESTED the TPS Sensor ?
Cleaned the MAF Sensor ?
Fuel filter & fuel pressure ?
Mar 30, 2011 | 1998 Ford Escort
Trimmer starts, but stall's out, and is sluggish
Get a can of starter fluid and an assistant. Start it up and spray some starter fluid into the air intake to make it run long enough to clear up the sluggishness. J.
Aug 02, 2010 | Homelite Mighty Lite Lawn Trimmer
The battery light goes on and off. The car is sluggish to start. I have a new battery and the alternator has been checked and is fine. ANy ideas?
sorry to say but i would take that battery back and get another. to have a sluggish start, is indicative a collapsed cell inside the battery. now new or not electrical items fail i the blink of an eye. ive had new ones right off the shelf...BAD!
Jan 06, 2010 | 2006 Saturn Vue
My car was a bit sluggish to start then 1 day wouldn't start nothing there at all tried it tem min later and it started and has been fine til the other day went sluggish to start drove to a few places then...
check/clean battery terminals, if ok check starter wires for voltage(while turning key to start) and tightening or corrosion. If all check out ok replace the starter. If you have no voltage at the starter check your relays and ignition switch. Hopefully this helps
Aug 19, 2009 | 1998 Nissan Maxima
Lands Phones Logo
109 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
