Question about GPS
Venturer gps hps 9308 how do you reload sd map card
Venturer gps hps9308 will not boot. it freezes up ?
Posted on Sep 22, 2010
After downloading the latest map for my VIA1505 my gps comes up with 'NO MAPS FOUND' when i turn it on.I've tried reseting it with no luck.When i try to reload the map it says my unit is up to date.Can't...
I finally fixed the problem myself(TomTom support not open on week-ends).I deleted all TomTom software and files,added an SD card for more memory,and then reloaded everything including new maps.Seems to be OK now.
Mar 13, 2015 | Tomtom VIA 1505 GPS Receiver
Maps not found
Reset the set.
And then try it.
Aug 20, 2008 | Magellan GPS
FINEDRIVE Card re-load
you need to reload the firmware in the unit and reload the map data on the SD card, this will fix your issues. as finedrive is not around anymore, here are the files:
here is the link to the instructions and install data.
http://www.flyupload.com/?fid=951808
install data
http://www.flyupload.com/?fid=6960824
and the map data
http://www.flyupload.com/?fid=9768281
See this solution; it was posted on Fixya:
Thanks
Iqbal
May 21, 2008 | Fine Digital FineDrive 350 GPS Receiver
My nuvi 3760T does not have enough space to load europe map. Can I remove preloaded north america map and reload at a later date without losing it?
If you have the map downloaded from the garmin website to your computer you could remove it and replace it later. However a better option might be to download the map of Europe to your computer and install it to a micro SD card. A 4 Gb card would hold the map of Europe and you don't risk losing your North America map. You can get details of how to set up the map on your micro SD card at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
While this link is mainly about how to update your maps it has a section on setting up maps on an SD/Micro SD card also.
Mar 26, 2011 | Garmin GPS
Stim Card was stolen can I get it replaced
The SD card for the 255w is to add additional storage memoy to the gps. The actual maps are stored on the device memory itself. if you need a new SD card, you can buy one anywhere at any electronics store or Walmart for that matter.. The 255w does not us a sim card like a phone does. If you need to reload the map to your device, you will have to go thru Garmin, download it to your computer, then upload it toyour Garmin via the USB cable.
Mar 31, 2010 | Garmin nuvi 255W GPS Receiver
Tom Tom XL Connected TT to laptop and selected scan and fix etc but dowload interupted and now says I dont have access to Map united Kingdom and republic of Ireland
I think maybe it needs to be reset mate, but take the sd card out before you reset it, press and hold the reset button for about 15 seconds and then turn it back on and then load the sd card and the maps should reload
Jan 02, 2010 | Tomtom ONE GPS Receiver
NAV CAM 2007 (GPS) NEW MAPS
Here is some other soft for your evesham device: http://www.driveway.com/NF98ogAJWR
http://www.driveway.com/i1EvQzR8FL
http://www.driveway.com/G3N0Y5jQ4s
When you finish the downloads, you need to unzip all the files, then copy the map files into the maps folder. Once this is done, copy the entire thig to the SD card and enjoy!
Dec 20, 2008 | Evesham Nav-Cam 7700 GPS Receiver
HP ipaq with navtec gps software and sd card fails
Ok, nice job Robert,
I'm posting your solution here to remove it from the unsolved problems list.
Solution by Robert:
This problem was finally resolved as a corrupted map file on the SD memory card in the hp ipaq 5550. Solution was to reformat the memory card using fat32 memory format. I used a SD memory card slot on my laptop and right click the drive letter and select format to format the memory card. After that, I reloaded map files to the memory card and all was OK. Note that previously I had loaded map files on the memory card successfully but that was not good enough. A reformat of the memory card was apparently needed.
I had also previously tried a hard full reset of the ipaq by pressing and holding the lower two buttons (calendar and itask) while holding in the reset button with the stylus for 5 seconds and resynced my contacts and reloaded the gps software, but this was to no avail. Try the re-format.
Jun 22, 2008 | HP iPAQ H5550 Pocket PC
FineDrive 400: Original SD card got corrupted!
install data
and the map data
Feb 14, 2008 | Fine Digital FineDrive 400 GPS Receiver
GPS Logo
689 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
