Question about RCA F32649 32" TV
Fuse blowout every time i put a fuse my tv sparks and blows out. help me
    President:
  • 3,130 Answers
Every time you put in that fuse and it sparks your probably causing more circuit damage as a fuse very very rarly goes bad for no reason.. Ok to the subject at hand. it you put back in a good fuse WITHOUT PLUGGING IN!! Next measure with an olm meter across the two legs on the plug on the end of the wire(the part you normally plug in.) Is there a short circuit?? yes? I would then start trouble shooting the front end of your main power supply like bridge recifyers,main b+ capacitor, the capacitor that goes across the ac line input as well as an VDR can short out in a surge. Now if that dosent get you anywhere your gonna need a schematic diagram. You can get that from howard sams photo facts. It available on line as a PDF for about 27.50. If you dont know what Im saying here then I really cant help you any farther and you will need to take the set to a quilified repair person as a tv even unplugged can hold 100's of volts. Now if you do know what your doing with solid state repairs by all means get the schematic and post it here for us to look at and we can assist you with this repair. Good Luck
Posted on May 21, 2006
Technics su-g75 drawing/schematic? when hit power button fuse in power supply blowout.
Fuses blow when there's an overload. This is most likely caused by a semiconductor device(s) shorted. In amps this is often cuased by speaker wires that have touched while on power. The main culprits are the devices on the heat sink. If they are transistors then connecting an Ohm Meter accros the terminals of the transistor(s) (amp switched off) will show as if you have touched the test probes together! More than one device might have blown!!
Dec 23, 2014 | Technics Audio Players & Recorders
Fix tv blowing fuses
when replacing fuses in a device....if, when you next apply power to the device and it immediately blows the fuse again : Do NOT put in anymore fuses. It is time to visit a TV repair shop.
Oct 30, 2014 | Emerson LC320EM9 32 in. LCD HDTV
Crt spark flyback
If fly-back transformer gets sparks, no doubt, the horizontal output transistor will blow out, at the instance you switch ON the set. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. I think the site will help you like people so much. Good luck.
Oct 22, 2013 | RCA 27V530T 27" TV
100 watt inverter blowout new fuse and keeps on blowing it out does it still work
Fuses blow because of excess current flow so check for shorted wiring or correct connection in the plug. Are you connected to something that is drawing more than 95 watts as that will overload the unit and blow fuses.
Feb 11, 2013 | Black & Decker 100 Watt Inverter...
Whirlpool microwave fuse has blown multiple times
It depends on which fuse and when it blows. Wish you had mentioned that.
But usually it's a defective door switch or door switch mount.
If the fuse blows at random times while it's cooking, it may just be a loose fuse holder. Those have to be replaced due to metal fatigue, not just squeezed tight with pliers.
If it blows as soon as you hit "Start" to begin cooking, you have a shorting high voltage capacitor.
If it blows when you open or close the door, you have a loose or defective door switch or latch.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Nov 21, 2012 | Microwave Ovens
My lawn mower fires up but idles slow and rough
No adjustments. Automatic governor. Replace spark plug. Ensure blade is sharp and oil is full. 30w oil. Always put Stabile in gas. When you remove spark plug pull rope several times to blowout cylinder. Spray a little WD40 in spark plug hole, then pull rope several times. Spray starting fluid in spark plug hole, replace plug, ensure plug wire snaps on tight. Clean replace air filter.
Aug 09, 2012 | Troy Bilt 5.5hp Self Propelled Mower
3 of 4 10 amp fuses blew in an aragon 8008 amp. sockets spark when attempting to put replacement fuses in.
The reason they spark is that there is still power and load when you put the fuse in instead of putting the fuse in put a mains light bulb with its terminals onto the fuse terminals and this will safely discharge your capacitors and making sure that your power is off put your fuse in there should be no spark and switch on if the fuse still blows you have faulty gear
Apr 01, 2011 | Aragon 8008 MK II 2-Channel Amplifier
Spark plug blowout
No, can't see how?
Make sure you lubricate spark plug threads with anti seize paste and don't over tighten.. usually hand tighten till plug bottoms + 1 flat of hex.
Aug 03, 2008 | 1990 Chevrolet Cavalier
RCA big screen tv
whenever fuse blows every time it is the indication of short circuit in tv. so please do not put fuse unless you know the cause of blowing fuse. these are the reasons of blowing fuse. 1 main filter cap.short. 2 rectifier diode short. 3 swithing transistor short 4 horizontal output transistor short 5 caps & diodes connected to flyback transformer short. 6 print short. 7 at last if every thing ok then flyback transformer defective. hope this will help. if you are not a tech person call skilled tech to fix it. good luck
Sep 24, 2007 | RCA P60828 TV
RCA F32649 32" TV Logo
51 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
