Question about Tomtom RIDER GPS Devices
REMOVE BATTERY HOW DO I REPLACE BATTEY FOR TOM TOM V3
    President:
  • 2,712 Answers
You cannot replace the battery.If you have a problem with the battery, please contact TomTom customer support. Don't forget that you can use your TomTom device in the car with the car charger and at home with the home charger or home dock even if you are having a problem with the battery.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 12, 2008
  • theofitz May 15, 2011
    Yes you can. Purchased 62 piece security bit from Maplin, which contains bits to remove the screws on my Tomtom rider, 6 screws in total. Two screws are hidden under two small round stickers.
Service agent in capetown for tom tom
Here is the link to a free classified ads in Cape Town. Find the Repair section. Enter TomTom in the search bar.
http://capetown.olx.co.za/
Nov 27, 2013 | Tomtom TOM TOM ONE WE V3 GPS Receiver
We replaced the alternater and battey....but it jst clicks....checked starter is good.. what up?
Murray,
What method did you use to check the starter? Were you able to place 12 vo;ts to it and watch or hear it spin? Was the battery fully charged when you installed it?
It does appear to be a low voltage situation or bad electrical connection, however. I suggest that you recheck the battery connections, that the terminals are clean,and battery clamps have been wire brushed with your battery post brush.
Make certain that the connection at the starter is solid.
Tom
May 07, 2011 | 1992 Suzuki Sidekick
How to replace battery in tom tom 500
You'll need a special 'torx' screwdriver to remove the screws to replace the battery. The battery and the torx screwdriver can be purchased together on eBay for less than $20.
Click here: http://bit.ly/c6sbyk
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 07, 2010 | GPS
How do you replace the battery for a tom tom one
Before you undertake this exercise, make sure that you are confident with your ability to handle small and fiddly parts as the unit is pretty delicate and sensitive to static electricity.
You also want to make sure that you have a suitable replacement Li-Ion battery.
At your own risk, the following are the basic steps required for the TomTom One V3.
You need to very carefully:
0) Check that GPS is fully functional (even while plugged to a power source) to make sure that your replacement did not cause any existing issues.
1) Power off and remove all plugs and SD card if applicable
2) remove all (four) security screws with a special screwdriver
3) gently lift the casing away from the screen paying particular attention to any wiring like the speaker wires.
4) unplug the speaker so that you can remove the cover completely. (Remove any holding tapes as required)
5) unplug the battery pack (Li-Ion, 3.7V, 1200mA) which has a small connector with 3 wires from the motherboard. The battery is usually secured by double sided tape that needs to be gently unstuck.
6) plug the replacement battery with 1200mA or higher current ratings (higher current is better, lower is Ok but will deliver shorter usage time) and secure using (re-used) double-sided
tape.
7) Re-attach speaker
8) Re-assembled back cover but do not tighten the screws too hard!
9) Recharge the unit battery making sure the unit is still functional while plugged in to a power source (PC or USB charger).
10) Enjoy your revived GPS!
Hope it helps: let me know how you go!
Jan 06, 2010 | Tomtom ONE GPS Receiver
Tomtom 1 v3 wont read new sd card help
Take special not of part 6
1. Remove the SD card
The card needs to be formatted properly first that's all,
2. formatting is better done in a card reader.
3. Right click on it and select format select FAT32 as the files system
4. Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
5. You now ned to select your tom tom which will also show as a drive.
6. In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
7. Then just copy ALL the files from the tom tom to your sd card
8. DO NOT USE CUT AND PASTE !
9. Once all the files are on switch off the tom tom and insert the sd card
It should now work
Sep 15, 2009 | Tomtom ONE XL GPS
Razor battrey
Did the phone show it was charging on the display? Was the charger firmly connected to the phone? The batteries will go bad after a period of time of recharge cycles. I have bought replacement batteries for my RAZR on eBay. Remove the battery and do a search on eBay for a NEW battery from a dealer using the battery P/N on the battery. I found a higher capacity battery for mine that lasts even longer on a charge than the original one that came with my RAZR. You can do a search on eBay for "RAZR battery". Look at the mAH rating on your battey, Try finding a replacement with the same or higher rating than your original. The higher the mAH rating, the longer it will last between recharge cycles.
- Jim
Jul 08, 2008 | Motorola Mobility RAZR V3
How to replace internal battery
Remove the Front facia surround Undo four screws holding internal works to outside body You will need a T6 star screwdriver for this. Remove internal works from body at the base you will see silver foil covering feel over this you will find 4 T5 star screws securing this remove these and also remove speaker by two locating T8 star screws. Gently remove the electronic board keep all locating cables intact You will then see two T4 star screws holding battery holder remove these and the plastic holder .Unclip battery and disconnect from Pcb Board fit new battery and reassemble. .
Jan 07, 2008 | Tomtom GO 300 GPS Receiver
Motorola razr battery problem
The only solution is to get a new battery. When you do, charge it completely when you first get it, then discharge it until it dies. This will maximize the life of the battery.
Nov 29, 2007 | Motorola Mobility RAZR V3
Razr white screen
behind the phone there is a battey cap press the silver button and remove the cap and then remove the battery and put it back... then it will turn on properly
Aug 24, 2007 | Motorola Mobility RAZR V3
Tomtom RIDER GPS Devices Logo
364 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
