Question about Denon DCM-370 5-Disc CD Changer
CDs skip on normal playback
I've had this on going issue where CDs are starting to skip on playback. Manifests as a brief 3-4 second pause. This occurs on both CDs and CD-Rs - there is no consistent pattern; the skips occur at different spots on the CD at different times. At times it is frequent and irritating enough to stop play; other times it may occur only once (or even not at all). It seems to occur more when unit is first powered on, although this isn't always the case. Coule this be an issue of laser alignment? Is it a reasonable fix? Or, should I start looking for another unit?
    Problem Solver:
  • 11 Answers
Hi, the most probable cause for this is the lasers light output falling off as it ages. Sometimes you can temporarly improve this by cleaning the laser lens with some alcohol. However the only real solution is to replace the laser.
If you are confident taking stuff apart you may be able to do this yourself. Almost all modern laser assemblies come fully calibrated so all you need to do is take the old on out and fit the new one.
The lasers often have the part number on the side of them. You can get spares from CPC in the UK. But a search for the part number should find you a spares supplier wherever you are.
Regards, Andrew
Posted on Sep 14, 2008
How do i get rid of message code 3 ??????
Actucally, there are a few ways to bypass Cinavia, but no program can remove Cinavia. If your video is a homemade movie or other personal recording, to play your recording without muting you may either:
· Pause the video, wait 30 seconds for the audio to be un-muted, then skip over those portions where the professionally produced material is used and continue playing the rest of the video, or
· Pause the video, wait 30 seconds for the audio to be un-muted, then play video from a different optical disc for at least 10 minutes before continuing playback of this video.
Mar 05, 2015 | Sony Playstation 3 (PS3) Console
Hi, I have an HHB Burn-It CDR 830. Whenever I'm recording, along about the 5th track in- the player starts to fuzz out. The time stutters/freezes momentarily, and then continues normally for a while...
If it's always around the same physical location on a given CD it would have to be a physical problem with the transport, not the lens.
Esoteric but comprehensive advice....
http://www.repairfaq.org/sam/cdfaq.htm
Sep 20, 2011 | HHB BurnIt CDR830 CD Recorder
Wont play the whole song
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat
within current Folder (if any), Repeat Folders (if any), Repeat
All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
May 02, 2010 | Element Electronics GC823 MP3 Player
Can not use with vontage phone
1 = start over at beginning of message (I think)
2 = save
3 = delete
5 = review message options (playback speed, etc)
7 = back up 10 seconds
8 = pause (# to mark for message segment repeating - whatever that is, any other key to resume playback)
9 = fast forward 10 seconds
# = skip to next message
* = cancel
By the way, you can get all of this (and more) by pressing 0 during message playback. Pressing 0 at any menu gives you help for that specific menu.
http://www.vonage.com/help_knowledgeBase_article.php?article=233&category=118
Mar 12, 2010 | Linksys WRT160N Wireless Router
3 disc Phillips cd player sometimes skips. It is
At some time in its life, the laser that reads the CD starts to get too weak to operate reliably. That's probably what's happening here. Unlike mechanical parts that can be inspected for wear, electronic parts tend to work fine one day, then the next, poof. The laser assembly is replaceable if you can locate the part and find someone to install it. An electronic service shop could give an estimate for repair. If you can provide the full model number, I'll see if I can find the part number.
Mar 08, 2010 | Teac AD-600 3-Disc CD Changer
My jensen wont play cds wen it dose it skips
use a common cd/dvd optic cleaner .... they are cheap .. what is going on is your cd player cant find a track so it shuts off ..
Feb 10, 2010 | Jensen Car Audio & Video
CDs skip
Hello
Ok, it sound to me that the laser lens which actually reads the cd's has some dirt particles on it.
There is a very cheap method of solving this problem.
Just go to any cd shop and buy yourself a decent laser lens cleaner disc, follow the instructions and you should be set.
Kind regards
Andrea
Dec 13, 2009 | Technics SL-PD6 5-Disc CD Changer
My DVD player has had continual playback problems for many months. It skips and pauses often while playing back DVDs and CDs. These same CDs and DVDs play flawlessly in other (much less expensive) players...
Might need a tune from bose repair man, Burnt dvds sometimes has problem but wipe normally fixes it. But cds i have't had problem burnt or orginal, scraches dont usally worry to much, Thats why thinking repair man.
Hope this helps:)
Cd normally hot from unit if its in for a while.
Aug 16, 2009 | Bose Lifestyle 38 System
How do i auto switchoff my lenovo y410 laptop
I'm not sure if your referring to sleep mode or not but I hope this helps There are several specialty key functions on the Lenovo Y410...here is a list....good Luck....please rate me ...The Fang
The following describes the features of each function key.
Fn + Esc: Turn on/off the integrated camera.
Fn + F1: Put your computer in sleep mode.
Fn + F2: Turn off the LCD screen (any subsequent operation will turn the LCD screen back on).
Fn + F3: Shift to other connected display devices.
Fn + F4: Switch between wide screen and normal mode.
Fn + F5: Enable/disable the built-in wireless networking feature.
Fn + F6: Enable/disable the bluetooth features.
Fn + F8: Enable/disable the touch pad.
Fn + F9: Enable/pause Media Player playback.
Fn + F10: Stop Media Player playback.
Fn + F11: Skip to the previous track.
Fn + F12: Skip to the next track.
Fn + Insert/NmLk: Enable/disable the Numeric keypad.
Fn + Delete/ScrLk: Enable/disable Scroll Lock.
Fn + Pause/Break: Pause to view the system information during start-up.
Fn + up/down arrow key: Increase/decrease display brightness.
Fn + right/left arrow key: Increase/decrease computer volume.
Feb 19, 2009 | Lenovo 3000 Y410 Notebook
MP3 files start skipping/popping after few minutes of playback
Sony say in the manual that if you record high bit-rate mp3's the sound may be intermittent. I feel this is due to the decoder having to move ALOT of bits around to play, try some makeing a disk with mixed rate mp3's on. e.g.) some 64Kbps, some 128, some 192, and some as high as you can get and see if there is any differ Luck
Mar 02, 2007 | Sony CDX-MP40 CD Player
Denon DCM-370 5-Disc CD Changer Logo
228 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
