Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Fridge is defrosting
My fridge is not cooling at all. It's defrosting, There is no water leaking out. The fan is on and the lights are on. Both sides of the fridge are deforsting. I turned the thermostat up but that didn't solve the problem.
  • 958 Answers
Please take a look at the compressor if it is running.
if the evaporator fan is running, the compressor should be running as well to cool the fridge.
if the compressor is running, then you have a problem with refrigerant. there could be a leak in the system.
have a qualified technician check your unit for further repair.
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
Hi there.I have an Amana Side by Side Refridgerator.We are having a problem with the fridge side not cooling enough.The Freezer side is working well.Have you any tips on how to fix it myself ?Cheers.
Check fan which blows cool to fridge compartment is working. Check fridge is defrosted automatically. If not do it manually and check, there will be cooling in fridge compartment. Over frosting will cover up the fan throw behind the freezer. If not auto defrost works, switch off and restart after 5 minutes. Still auto defrost problem, do it manually or replace board.
Jan 27, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Freezer is cold, fridge side is not. Fan runs, compressor seems to run. water puddle on the floor on fridge side. anything available for DIY?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 01, 2011 | Amana ASD2620HRZ Side by Side Refrigerator
Freezer is working, but fridge is not. The light comes on, but it is not cooling. What could be the problem? I don't hear the fan coming on for the fridge side.
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Dec 26, 2010 | Hotpoint Refrigerators
Magic Chef fridge, freezer compartment leaks water (side by side). Can't find a drip pan anywhere on fridge.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 08, 2010 | Magic Chef Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
Motor runs, freezer defrosting and fridge won't cool
If you have frozen coil at the back of the freezer section, then the defrost thermostat is usually failing. Allow the fridge to defrost completely overnight. If the fridge restarts cooling immediately after defrost, then the problem was the defrost system. In that case the fridge will stop cooling again in a couple of days, as soon as the evaporator coils restart freezing and the condenser goes under stress with the whole cooling system loosing efficiency.
Nov 25, 2008 | Jenn-Air JCD2389G Side by Side...
Kenmore side by side Refrigirator
Sounds like you have a defrost problem. The timer could be playing up and taking too long to defrost, which causes the evaporator to ice up, hence no cold air to the fridge and the water line freezes up, hence no water dispensed. When the timer does eventually defrost the fridge then everything returns to normal. This could also be caused by a faulty defrost terminator or bad connection on the defrost element.
Sep 15, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
64 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
