Question about Nokia E61 Smartphone
Nokia E61 LCD Light Black Out
Dear all,
My Nokia E61 LCD Light goes Black Out/turn off and won't turn on even I try to hard reset etc. I have the problem after charging for several hour during night sleep, usually I have no problem but when I woke up in the morning, the LCD Light wont turn on although I can see the menu etc but it is very hard cause quite dark. I try to change the battery but still having the same problem. I bring to the service center and they do not know what is the problem also...huffff...
Could anyone help me in finding the solution for my problem? Thank you.
Regards from Indonesian Nokia E61 Fans!
  • 1 more comment
  • Anonymous Oct 02, 2008
    same problem! i can see the menu and everything but its real dark. Should i buy a new screen or is it the phone? thanks
  • complicado Jan 10, 2009
    my screen will not open up although the key pads have lights on and i guess the phones functioning. sadly dead LCD
  • Anonymous Feb 21, 2009
    AM going throught the same problem .
I have the same problem too. The backlight won´t work. Is there a way to fix the backlight by substituting it?
Posted on Oct 25, 2008
Hi my Nokia e63 screen is upside down,I have tried to punch codes *#5511# up to *#5514# but no response,I have even tried hard reset but to no avail.What else can I try
Make sure it's only upside down only. I mean see whether there are any black stripes, black pixels etc. I think your display contacts needs to be cleaned or get a replacement lcd
Jun 22, 2017 | Nokia Cell Phones
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
My nokia xpres phone it says memory ful even wen i format it dosnt help
may be you have so many applications in your mobile try doing hard reset by following instructions beneath
  • Enter the code: *#7370# and press Yes to confirm initialization.
    • Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
  • To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
  • on/off + * + 3
    • Before making a Hard reset better backup all your important information: contacts, memo...etc
Jan 04, 2012 | Nokia Lands Phones
I have a 37LG505H-UB LG LCD TV and when I watch it, it all of a sudden starts scanning for channels on the RF input even though I have it hooked to HDMI on the STB. It won't stop and when I turn it of
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jun 03, 2017 | LG Televison & Video
Just hard resset phone by pressing *, 3, green button (call accept) and power button in same time. With this procedure i solved problem with my E61
Man, i've done this too on my 5310 xpressmusic, and now, when I try to power it up, is asking me for pin code, then show the Nokia 2 hands picture, and then the light is on and off, and then the phone turn off. Can any1 help me ?
Feb 04, 2011 | Nokia E61 Smartphone
Hi, please can you tell me how can i make a p...
please helpme. i connect a wlan wifi .but not connected.
network connection is failed the message is come
May 20, 2010 | Nokia E61 Smartphone
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
Nokia E61 Lock Code
hi,
your IMEI: 356213000156447
mastercode:
103707476x
The mastercode can be entered instead of standard security code.
note: i have a demo unlock software so, the last degit is hide please try 0 to 9 as place of x.
Thanks for using FixYa.
Feb 02, 2009 | Nokia E61i Cellular Phone
E 61 won't power up European model.will not even synch with laptop
Take the battery out for one minute and then re insert and try again. If this does not work check if your charger is working, and check the battery as it may be defective.
Oct 11, 2007 | Nokia E61 Smartphone
Soft Reset
A soft reset would be simply to turn off the phone, remove and re-insert the battery and restart the device. To hard reset the phone (erase all data stored in memory and return to factory settings) dial *#7370# It will ask you if you are sure, then it will ask you for the security code (by default this is 12345). Your phone will then reboot.
May 29, 2007 | Nokia E61 Smartphone
Nokia E61 Smartphone Logo
274 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
